Question about Lexmark X2350 All-In-One InkJet Printer
Eratic behaviour The cartridge is banging against the sides of the cover. There was no indication as to a problem because the printer was working perfectly the day before
    Genius:
  • 2,785 Answers
There might be a hardware failure please send it for servicing
Posted on Apr 04, 2008
I have the cover open on my canon pixma mx410 cannot seem to figure out how to get the old balck ink cartridge out??
Is the power on? Close the cover (lower the scanning unit by raising it first then let it down gently) and make sure the all-in-one is plugged in. Then turn it on with the power button. Wait for the unit to stop its warm-up and self-test then reopen the cover. The cartridge carrier should move to the installation/replacement position.
Then pinch and lift up on the lid of the right side cartridge cover. (The cover is an angled piece with one side going down into the front of the cartridge carrier; you need to press in enough to get the tab to unlock from the carrier.) Now lift up the current black cartridge.
Unwrap the new cartridge and remove the orange tape. Carefully place the new cartridge into the slot without squeezing it or banging it against the sides of the cartridge slot. (The label should be up and towards the center of the printer.) Then push the locking cartridge cover down until it snaps into position. (Make sure that it is fully down.)
Then close the cover again.
I hope this helps.
(if the cartridge carrier doesn't move when the printer is on, try reaching over and sliding it when the printer is off. Look for foreign objects in the cartridge carrier path and remove anything (including small scraps of paper) that may block the travel. I recommend using a flashlight to check for foreign objects.)
Sep 01, 2011 | Canon Pixma MX410 All-In-One Printer
Lexmark z617 printer not working, printer cartridges shooting from side to side when poweed on or lid opened & closed
When you say "printer cartridges shooting from side to side when poweed on or lid opened & closed", do you mean that it's banging from side to side? Turn off the printer. Remove the cartridges from the printer. While the cover of the printer is open, check inside for anything out of the ordinary like any tapes or strips that are loose. If none, turn off/on printer and reload the cartridges. If the banging noise is still present, I suggest you contact Lexmark Technical Support to further investigate the problem. It might be a mechanical problem in the printer.
Jul 15, 2010 | Lexmark Z617 InkJet Photo Printer
DOESN`T PRINT -
Hello. Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source. Check the inside of the printer where the ink carrier is. Look for anything out of the ordinary (loose strip, belt or springs). If none, close the printer, plug the power, and when the printer's ready, re-insert the cartridges. If printer is still banging the carrier to the sides, it's a hardware/mechanical problem in the printer. If that's the case, I advise you to call Lexmark.
Mar 31, 2010 | Lexmark X1270 All-In-One InkJet Printer
Canon Pixma iP 6210D: cannot replace cartridges
the drive control is malfunctioning and costs more to repair than replace
Jul 07, 2009 | Canon Pixma iP6210D InkJet Photo Printer
Clear jamming
The noise means that the encoder strip is missing or covered with ink. It is a clear mylar strip with black bars on it. It connects to a spring on the left, runs behind the carriage thru a slot and to a hook on the right side.
Jun 30, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark z23 cartridge banging
The encoder strip may have become unseated. please follow the steps given below:
The embedded links in the table lead to specific troubleshooting steps.
1 Turn off the printer and disconnect the power cable from the back of the unit.
2 Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and back up to get it into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it first forward and then back.
4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
5 Reconnect the power supply and turn the printer back on
If the issue persists after you have attempted the steps with a new color cartridge, continue to Contacting Lexmark.
Jan 31, 2009 | Lexmark Z2300 InkJet Printer
Loud irregular noise from printer during and after printing
This is the common problem of clp 300. you are required to change the black developer. for this you may approach authorised service center.
Dec 29, 2008 | Samsung CLP 300 Laser Printer
Replacing Drum Catridge
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
DRUM CARTRIDGE REPLACEMENT
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Aug 15, 2008 | Sharp AL-1217 Copier
Unfortunately, this is a known problem with Lexmark printers. First, try turning the printer upside down and shaking it - it's been known to work. If it didn't help, try cleaning the parts with alcohol solution. Wipe everything inside including the top strip, the metal bar and then pull the ink cartriges out and wipe the copper and the actual cartrige too. And to finish it, hit the side of the printer a couple of times.
Apr 04, 2006 | Lexmark Color JetPrinter Z23 InkJet
Lexmark X2350 All-In-One InkJet Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
