Question about iLO (2 GB) MP3 Player
Hey you seem like you know alot
When i plug my ilo into the computer, nothing happens. I also tried putting the disk in to and that doesn't do anything, can you help me with my problem please?
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
Hey there. I have a problem with an external harddrive. "My Passport Essential". When I connect it to my compute sometimes nothing happens and sometimes "Local Disk (E:)" shows up in my...
The problem might be a loose connection or bad configuration file (an autostart ini file that makes the hard-drive do certain things when plugged in) in the root folder of your hard drive. Are you able to connect to it sometime or it doesn't work at all? If you can read it, try backing up all your data and format the hard drive and copy back the backup again. But remember to copy only the needed files and not the system or ini files.
May 06, 2011 | Western Digital My Passport Essential...
HOW TO DOWNLOAD MP 3 PLAYER
YOU CAN'T DOWNLOAD MP3 PLAYER CAUSE IT'S A DEVICE..
YOU CAN BUY IT TO STORE..IF YOU MEAN DOWNLOAD MUSIC,SIMPLY PLUG IN YOUR DEVICE TO PC,THEN COPY AND PASTE MUSIC FILES TO YOUR DEVICE..
THANKS FOR VISITING FIXYA,MAY THIS HELPS YOU..GOODLUCK
Feb 25, 2011 | iLO (2 GB) MP3 Player
I connect my mp3 to computer but nothing happens
Well, try go to the Start Menu, and go to the All Programs, then Accessories, then System Tools, and finally Disk Cleanup! This will allow you computer to clean up all excess junk or programs that you haven't used to free up a ton of space!
If you already did that, depending on the model/ make of the MP3, did it come with a start up disk, and instruction? If not, this is what I would do, go to My Computer, and check to see if the MP3 drive is active, then double-click to open the window, and then copy and paste your music on there, that you have save in your My Music Folder, and see if the MP3 have your songs on there, this is the manual way of putting music on any MP3 Player, if Not ?
Send me some info: Maker/ Model ; Brand Name; GB/MB on MP3; yes or no on the start up disk?
Jul 27, 2009 | Audio Players & Recorders
Tarantula doesn work after installing new firmware
there seems to be alot of firmware issues with alot of razors products at the moment, use another keyboard for the minute and navigate to their site, downgrade your firmware to the one that worked. or alternatively restore your computer to a restore date that occured before you installed the new firmware/drivers.
hope this helps
kev
Nov 30, 2008 | Razer Tarantula RZ03-00070100-R2U1
Recording Fall, Invalid disk
Try using Sony +R discs. or +RW's are good, any brand as long as they are +'s. For some reason alot of +R discs brands will not work, I wait and just get Sony +R or the +RW's on sale and stock up and I have no more troubles. Mine is the 05MU. The ZU is a little strange with the RW but will still record. Hope this helps.
Sep 24, 2008 | iLO DVD Recorder DVDR05
Ilo mp3 player
First check your USB cable for cuts or invisible breaks,its better you replaced a new one.If nothing happens just take out batteries and leave it for 3 hours and put it back again and try to check if it's working.If still not working then do some reset procedure..
To reset the MP3 press and hold both Menu and Select (center button) for about 5 or 10 seconds. If the Ipod is alive this will reset it
Hope this may help you;
DON'T FORGET TO RATE;
Regards,
VOTIT
Sep 06, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player
take it back and try a nother one if you get the same problem then i suggest you perches a hub carrier with it own power sorce as all mp3 need 2.0 or moor
Feb 04, 2008 | iLO (2 GB) MP3 Player
I cant download songs
download music to mp3
Jan 31, 2008 | iLO (2 GB) MP3 Player
Slm01 mp3 player
5546516651688526516516513
Jan 20, 2008 | iLO MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
