L1 SHOWING ON SHARP COPYER SF756
WHILE COPYING SLIDING DOOR HIT BOX AND STUCK IN MID FLOW ! CANT RESET AND DISPLAY NOW SHOWS L1... CAN THIS BE EASY FIX ? IS THERE A HIDDEN RESET BUTTON? PLEASE HELP..
    President:
  • 2,072 Answers
An L1 generally means the lamp carage is not moving. Remove the glass and see if that lamp assembly moves back and forth freely or if it is hitting something in it's path.
Posted on Apr 04, 2008
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
Ux355l copyer , when i press copy button to make a copy it say press wrong key, can u help me.
I tend to think that you are pressing wrongly. Place the document to be copied facing down on the fax document side and then press COPY/HELP key1 Load the document(s) face down.
(Maximum of 10 pages.)
The display will show:
READY TO SEND
• Set the resolution and/or contrast if RECEPTION
MODE
desired. (The default setting for
copying is SUPER FINE.).
2 Press the COPY/HELP key.
COPY/HELP
COPY MODE
START KEY: SINGLE
COPY KEY: MULTI
? If you are only making one copy of the original (or of each original)
and don't want to make a reduction or enlargement setting, press the
START/MEMORY key twice. Copying will begin.
and want to make an enlargement or reduction setting, press the
START/MEMORY key and go to Step 5.
3 Press the COPY key (MULTI ) if you
want to make multiple copies of each COPY/HELP
original.
ENTER # (01-99)
4 Enter the number of copies per
original (if the number is less than 10, 0 3
enter a "0" before the number).
Example: Three
copies per original
COPY RATIO
Originals
BC
A
MULTI COPY
AA BB CC
A B C
You can get its manual here.
Jan 08, 2011 | Sharp Office Equipment & Supplies
SHARP COPY MACHINE AL 1631 FLASHES A L1 ERROR
Most likely when removing a copy someone hit the scan lock on the front of the machine.
Look on the front , bottom side of the scanner where the paper comes out. You will see a latch that is used for shipping the machine that is more than likely locked.
Thats what causes an L1 90 percent of the time. Just slide it to the unlocked position or take a small screw driver and remove it and throw it away. You can put a piece of tape over the opening to keep dust and moisture out
Jul 15, 2010 | Sharp AL 1631 Copier
Sharp copyer model Al-1655Cs has error code of L1-00
The problem in the exposure section.Check the mirrors forward motor and others mechanical parts.
Oct 04, 2009 | Sharp Office Equipment & Supplies
We have a Sharp AL-1641CS Copier and it does not want to copy. On the display window it shows L1. What does this mean?
this a problem with the scanning section the lense motor is not moving is stock or broken check for opstraction if not the lense motor is broken
Jul 07, 2009 | Sharp Office Equipment & Supplies
Erorr L1 Apears in the display
L1 IS USUALLY TO DO WITH THE SCANNER POSITION CHECK THAT THE SCANNER LOCK SWITCH HAS NOT ACCIDENTLY MOVED CAUSING A LOCK YOU CAN CHECK THIS BY LIFTING THE LID AND TURN THE MACHINE ON AND OFF IF THE SCANNER IS FREE YOUN WILL SEE IT MOVE TO THE HOME POSITION.
Jun 11, 2009 | Sharp AR-5316 Advanced Digital Imager...
Systen Error L1-00
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, and turn the power back on.
If this don't work, turn off the power
and wait 10 seconds to reset.
Mar 26, 2008 | Sharp AR-168D Copier
Sharp sf756 copier
Paul, L1 is a problem with the sliding glass, it either got stuck or obstructed when doing a copy or you have a clutch issue
ANdy
Jan 14, 2008 | Office Equipment & Supplies
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
104 people viewed this question
jasbo
jasbo
