I have purchased an ex-lease Lexmark T614n Laser printer through an online auction. However when Unpacked there were no cables included. Is it possible for me to purchase a set of cables from you or one of your dealers here in Brisbane? I believe that **** Smith ,Browns Plains is our closest store but I'm not sure that they carry much in the way of cables etc. An idea of the cost would be appreciated. Regards Ben Johnston Ph 07 3297 0729 Fax 07 3297 1960
    Genius:
  • 2,035 Answers
You can Lexmark support and get the information:
by this link::http://support.lexmark.com/static/229-1-0-179.html
Posted on Apr 04, 2008
SOURCE:
Just unpacked new 901, loaded drivers etc, wireless set up, no problem but keeps saying "There is a problem with the printhead" I have taken head out, cleaned it but to no avail
normally printer head is very sensitive. you will need to contact your point of purchase of your printer or contact the service center for lexmark
Sep 10, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I have just received a lexmark t522, which was an ex-work printer that was attached to a network. i want to use it as a stand-alone printer now. when it was attached at work it worked fine, but now keeps...
This printer has both a USB and parallel printer connection.
I suggest you connect this printer to your computer using the USB printer cable and install the printer driver software on your computer.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Aug 03, 2011 | Lexmark T522 Laser Printer
Printer says error #1203 what do I do
Problem Error 1203 ; 1203 error message; 1203 cartridge error; Cartridge short error Solution Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads.
Resolution
  • If the problem occurred immediately after the printer was purchased and unpacked from the box, please contact Lexmark Technical Support for assistance.
  • If the problem is occurring during the normal printer lifetime, the procedures below will help you to resolve it.
Troubleshooting a Communication Error between the Cartridge and the Printer click on this link and follow the steps listed, hope this helps! http://support.lexmark.com/index?page=content&id=SO3683&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X5495&searchid=1286737658844 Please leave rating ;) thanks
Oct 10, 2010 | Lexmark X5495 All-in-One &USB...
I recently purchased an acer computer that has windows vista. I have a hp2200dn laser jet printer and I want to hook it up by ether net into a wireless router. Unless this printer is wireless. I have a...
All you should need to do is connect the HP printer to your wireless router via Ethernet cable (which should be included with the printer). Follow the instructions that came with your printer to set it up on your computer.
May 13, 2010 | HP LaserJet 2200dn Printer
In my printer lexmark e 232 is switched on the "!" sign and it does not print. Can you help me??? Thanks
with lexmark printers yout try the following steps
1) unpluged all cables including the power cable.
2) press and hold the on/off switch for 20 seconds
3) reconnect all the cables and then try.
IF it does not work then reinstall the drivers
May 07, 2010 | Lexmark E232 Laser Printer
A Lexmark printer E350d has a message "photocon". What does it need?
Photoconductor unit (drum unit).
These are available new and remanufactured on internet auction sites.
Note that the photoconductor unit is EXACTLY THE SAME (other than the label and part number) as the one for DELL 1720.
Dec 28, 2009 | Lexmark E350d Laser Printer
Lexmark E210 laser printer driver not working
I had the same problem two years ago and purchased the adaptor also .The port is correct. My adaptor never would work either. The correct answer,for me, was to purchase a Parallel port PCI card and install it.  I am still using it to this day as both the paper and the ink ribbon  on my pin printer is a lot less expensive for making copies that I don't need to be letter perfect.
Feb 17, 2009 | Lexmark E210 Laser Printer
Need USB cable
Well first check to see if it was supposed to be part of the contents.  Usually one of the flyers or manuals included will tell you if it should have come with it.  If it wasnt to be included, the simple way to obtain one is to drive to wal mart, and ask them for a usb printer cable.
Jan 04, 2009 | Lexmark Computers & Internet
I have just unpacked a HP photosmart C4205, which I'm unable to connect,because there is no USB cable in the box. Having looked at the connection area, it seems to be a specialised connection cable. It's...
hi,I also have a hp..and the cable did not come with the printer.you need a usb connector that will go into your printer and connect into the usb port on your pc.you will see that the connector is smaller for the printer connection so make sure you get the right one.usually called.printer usb connector in store.
May 12, 2008 | Office Equipment & Supplies
Purchased a lexmark X1150 printer that was kept in the box until recently unpacked to find out the disk and user guide sent is for an X1100 series. How do we get the right software needed to program...
Here is a link to download what you should have gotten on the CD.
Just choose the Operating System you are running
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X1150
Hope this helps
Thanks for reading!
May 02, 2008 | Office Equipment & Supplies
Open Questions:
jasbo
jasbo
Ekse
Marvin
Marvin
