Question about Microsoft Xbox Console
My xbox turns on but wont read discs or dvds?
I turn the xbox on and it goes to the screen to set the clock I set it then try and play a game but it says theres no disc? Do I need a new laser to read the games, can I fix it myself? How much will this cost? Thanx you guys rule!
Your dvd drive is broken , cant be fixed you need a new xbox
Posted on Apr 13, 2008
Your dvd drive is broken. Thats what it sounds like to me. It cant be fixed you need a new xbox sry
SOURCE:
@[email protected] Loco Xbox 360 Problem Guys I have no idea whats wrong with it. It's not playing any games. The laser reads CDs and DVDs flawlessly. The crazy part about it is that it DOES READ the games initially...
It seems your laser isn't reading the second layer on the games. Regular DVDs have only one layer of information, Xbox 360 games are "Dual Layered" meaning twice as much information in the same area. I would recommend buying a replacement laser from eBay and installing it yourself (as you already know how to take the Xbox apart)
Feb 17, 2011 | Microsoft Xbox 360 Console
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
My 360 only plays cds or dvd s wont play games please advise
Feb 15, 2010 | Microsoft Xbox 360 Console
Disc error
its the disk drive xbox will fix for 100 dollars this just happend to me finally i called them and they told me its the disk drive and soon it wont read dvds either
Apr 14, 2009 | Microsoft Xbox 360 Arcade
Xbox 360 Wont Read Games or DVD's
take out your hard drive and then turn it on restore factory settings and plug it your hard drive back in
Feb 21, 2009 | Microsoft Xbox 360 Console
GAMES/DVDS WONT PLAY
Most probably YES. Your xbox doesn't detect the disc because the laser can't read it. Either it is damaged or the disc is dirty or scratched. Try several disks, and if the problem persists then you'll know for sure that it's the laser unit.
If you found this solution helpful please rate it. If you need further assistance feel free to post a followwup comment.
Feb 13, 2009 | Microsoft Xbox 360 Console
Will not play games
Make sure discs are not scratched. Try cleaning the discs using rubbing alcohol and a soft cloth.
Jan 31, 2009 | Microsoft Xbox 360 Console
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Microsoft Xbox Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
