Question about Forfex FX 652 Hair Trimmer
Replacing battery in forfex fx652
Have a replacement battery but unable to remove back cover
  • haircuts2you Jan 29, 2009
    see above posting...what to do now?
Hello, where did you get the replacement battery????
Posted on Feb 19, 2010
  • geeha Oct 16, 2010
    take the whole trimmer to batteries plus and they will build you a new one for around $20.
  • kellyfries
    kellyfries Dec 23, 2012
    Is there any where else that does that? I do not have a batteries plus near me
Take blade off. remove 2 tiny screws holding blade retainer . pull forward and remove front.take small screw out of battery door.once these steps are done case can be seperated.
Posted on Sep 28, 2009
  • robert5196 Jul 09, 2011
    Not enough instruction detail. I have a FX652. I do not find the "2 tiny screws holding blade retainer". Where are they located?
  • wonderraven
    wonderraven Feb 20, 2013
    I took the blade off and removed the screw holding cover, but the cover still will not come off.
Unable to connect my blackberry to wifi. it says unable to authenticate network.
Try a hard reset: With power ON, remove the back cover and pull out the battery. Wait about a minute then replace the battery and cover. Power up and wait patiently through the long reboot 5 minutes.
Also check the wifi encryption is compatible with your phone?
Maybe an option to goto a cafe with a wifi hotspot and try logging in there ... does that work?
cheers.
Oct 22, 2013 | D-Link Dlink Dir-600 Wireless Router...
Need to order a replacement battery and manual for Forfex model FX766
Here is the phone # to manufacture of your Forfex trimmer 800.326.6247
Mannys-sharpening.com
May 08, 2011 | Forfex FX766
I am look for a charger for forfex babyliss pro model fx652 3.6v dc 1a
I have a charger for a forfex clipper fx 652, if you contact me sweenytodd@operamail.com I can give you details...
Sep 14, 2010 | Forfex FX 652 Hair Trimmer
I need a battery
hi you could go to your local supermarket or even go into your locall electronics store
Apr 15, 2010 | Forfex FX 652 Hair Trimmer
I have a Sentry OA5835. I am unable to open with factory combo and key. help
Sounds like the batteries are dead.
How to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 11, 2010 | Sentry Fireproof Safe
Forfex blade reinstall
I have the Forfex babyliss 720 and I can't get new blades installed in it. I have tried 8 times and someone else has tried 5times. Do you have any instructions on this model.
Thanks
lchardt@embarqmail.com
Dec 16, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Power adapter for forfex fx652
There are very few parts available for Forfex products, are you sure it is the power adapter? If the clipper is 3 years or older most likely it is the battery inside the clipper, check their website for service centers.
Dec 20, 2007 | Forfex FX 652 Hair Trimmer
Forfex trimmer FX766 won't charge
Angehair,
It is most likely the battery, don't even try to open the case if you don't know what you are doing, Forfex will not replace the batteries in these small trimmers as they state it is too labor intensive, I am working on obtaining batteries for these units.
They have to be soldered in.
Dec 07, 2007 | Forfex FX 766 Hair Trimmer
Forfex FX 652 Hair Trimmer Logo
1,413 people viewed this question
Top Forfex Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
