Posted on Apr 04, 2008
Hp 1018 Driver for windows98
I purchase hp 1018 New printer but when i install it the error is dll file currept, but it,s work in windows XP. I need to windows 98 driver for hp laserjet 1018
  • 7 more comments
  • Anonymous Apr 30, 2008
    hp laserjet 1018
  • Anonymous May 11, 2008
    have the same, can somebody help ??
  • Anonymous Jun 07, 2008
    wdwadf
  • manu1984aug Jul 03, 2008
    same
  • Anonymous Jul 05, 2008
    need to windows xp driver for hp laserjet 1018
  • Anonymous Aug 28, 2008
    hp laser jet 1018 printer install on win xp but not installing un win 98
  • vazimkhan Sep 25, 2008
    I have HP 1018 printer but i have no driver for win 98 pleae help me.
  • Anonymous Jan 31, 2009
    hp1018 win98
  • Anonymous Feb 20, 2009
    I need hp 1018 laseajet priter driver
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5055
Points
7
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4870
Points
I need to download for laserjet1018 printer driver
Anonymous
Level 1:
  • Posted on Nov 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4870
Points
Anonymous
Level 1:
  • Posted on Dec 04, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4870
Points
  • Anonymous Dec 04, 2008
    GET A LIFE YOU PEOPLE -.-
A
Anonymous
A
Anonymous
Need to windows xp driver for hp laserjet 1018
Anonymous
Level 1:
  • Posted on May 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4870
Points
Windows 10 64b update doesn't suggest my printer nor communicate with it. My printer HP Laser Jet 1018.
The HP LaserJet 1018 is somewhat compatible with Windows 10. I would recommend using the Vista x64 driver. All you have to do is go to hp.com and click support. Then type in HP LaserJet 1018 and click search. Find the Drivers button. Select Windows Vista x64. Then download the driver. The .inf file is what you want to right click. Click Install. It should say "Installation Successful"
I accidentaly changed the language, how do I get back to english
Go to the Printer Properties, Printing Preferences, or Document Defaults are Displayed in an Unexpected Language so trie changing the language from there if not then there are two ways to correct this problem. The first is to download the printer driver from the HP Web site and install it. The second involves replacing the .DLL file the printer driver uses to obtain the text that is displayed on the screen.
There are two ways to correct this problem. The first is to download the printer driver from the HP Web site and install it. The second involves replacing the .DLL file the printer driver uses to obtain the text that is displayed on the screen.
1. Uninstall the printer driver.
2. Run the Scrubber, located as shown below on the Starter CD, for the desired operating system.
1. For Windows 9x and Me: \UTILS\SCRUBBER\WIN9X_ME\SCRUB9X.EXE
2. For Windows 2000 and XP: \UTILS\SUPPORT\SCRUBBER.EXE
3. Download the latest version printer driver from the Internet and install the new driver.
4. If the properties are still displayed in the unexpected language, proceed to the Replacing the language .DLL file section below.
(To install the driver go to the hp website that is hp.com/support )
Select Start and then Search.
2. In the All files and folders box, type the name of the .DLL file and select Search.
3. Using the Explore window, locate the first occurrence of the .DLL on the hard drive.
NOTE: Replace each occurrence of the .DLL file in the \WINNT\SYSTEM32\SPOOL\DRIVERS\W32X86\3 directory and any subdirectory where the file is found, \WINNT\SYSTEM32\SPOOL\DRIVERS\W32X86\hpdeskjet_6800421c.
4. Right-click the folder that contains the .DLL file to be replaced and select Paste.
5. Select Yes when asked to replace the file.
6. Repeat Steps 1-5 for each occurrence of the .DLL file that was found.
ALL THE BEST
1helpful
I want to instal hp 1018 printer driver for windows98 o/s but dont find the site from where i can download it
You can download the whole Software+Driver Solution (~200MB) Free from here.
I hope this will help you out!
If I was helpful, Kindly do Rate!
Regards, Waqar.
3answers
Printer does not print
Did you install the proper drivers ?
1helpful
I can not print my documents
I will continue to test this and report if I encounter any problems.
The solution is to remove a monitoring component of the HP printer driver. Open registry editor and browse here:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
Delete the "HPLJ1018LM" 'folder'.
Also open Windows Explorer and browse here:
C:\WINDOWS\system32\spool\drivers\w32x86\3
Rename the file "ZLhp1018.DLL" to something else, such as "ZxLhp1018.DLL".
Restart your computer.
Sharing now works fine.
But if you are not sharing then check printer cartridge and if still problem then you follow the path:
1-open the control panel and click add/remove program
2-uninstall the printer driver
3-then new install printer driver
4-keep default setting of your printer.
4helpful
Drivers for hp1018l aserjet printer for windows98
i do not have the cd of the hp 1018 laser printer now,i want to download the driver fro the internet.Thanks.
9helpful
5answers
How do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
2answers
Help me
i read wat u all complained above n i'm moved, but if u use win xp with service pack 2 and u are connected to the internet, then u don't need the driver CD again. as long as xp is able to detect the new hardware connected, it will only take time for it install and copy all the files. i bought the same printer 1st week of june n i did not use the driver at all.xp did it all for me... for more help u can contact me.
38helpful
17answers
Fatal error installing HP 3055 all in one
OK, here is my debugged/tested solution.
I know your error refers to a different installer MSI file (CIOUM32.msi) but the installation component in your log file (ipm12.A4B24390_80AD_4BAF_B8FD_C670FE0DB586) is identical to the one that was giving me trouble as well (i.e. points to the same service/file). So it is definitely worth a shot to try this solution out as it will only take a few minutes.
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
k24674
Grand Canyon Tech
Grand Canyon Tech
