Question about Toshiba Satellite A105-S4004 Notebook
Laptop won't power up
I've had the laptop on for a few days when I noticed a lack of activity.The power/on/off/battery etc icons were lit, but no life on screen. I pressed the On/Off button and then the whole thing died. It seems as if there is a malfunction within the On/Off button, but I doubt that's the problem. I've checked there's nothing wrong with the adaptor, when I connect the front blue/yellow icons come to life, but no activity when I depress the On/Off. I wondered if over-heating might have been a problem, but I've discounted that now. To all intents and purposes the laptop has died! Which is a shame. I've got a lot of stuff in this!
Any thoughts, Len
  • 4 Answers
Hi Pastor Len
Try to depress the On/Off button and hold it down for 5 - 10 Seconds. If nothing happens then the Toggle of the switch is brobably broke!!! You will probably be able to have a technician fix it for you, if not, you could remove the hard drive (yourself, or a Technician) and have it attached to another computer to retrieve any data.
Regards, ast9tjk
Posted on Apr 04, 2008
6ya staff
SOURCE:
Model S400CA-CA006H, Power ON, only back lit blank display. Battery icon is green while the BULB icon LED is orange in colour.
  • rjsymmes has the most accurate solution. Start with a battery replacement. Next course of action is to use a Bootable Media Source (Windows Disk or Recovery Disk) to see if the laptop responds and can have the Start Up repaired. If a Boot Media fails, then examine RAM, Hard Drive removal, then boot. Last resort Motherboard.
Jun 22, 2014 | ASUS Computers & Internet
Laptop won't startup on power or battery
Step 1:
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Unplug your laptop while it is running. If it still works, the battery has been charging. If it shuts off, or doesn't hold a charge very long, you have a bad battery. Unplug your laptop while it is off, then try to turn it on. If the battery is bad, your laptop probably won't turn on at all. Turn off your laptop's screen-saver when testing its battery. The screen-saver will conserve the battery and not give a clear time frame for how long your battery can really last. Click the battery icon on your laptop when it is unplugged. It can tell you how much battery life you have available. This icon is usually located in the bottom right corner of your screen and will provide the percentage of battery power you have left. Keep track of the time it takes to go from 100% charged to 1% charged. If this takes less than an hour, your battery is probably beginning to fail. You can also try this every week or two to see if your battery holds a charge for shorter periods. Factor in the amount of time you have used your laptop. Most laptop batteries last 2 to 3 years or about 500 charges. Wait a few days before determining whether a new laptop battery is faulty. New batteries sometimes take a few charges to build up to their maximum run time.
Feb 07, 2013 | ASUS F3SV-B2 Notebook
Lenovo Z570 powers on but screen is black
if you have an external monitor or a smart TV you can hook it up to that to see if it even works. If it works then you look real close to the screen of the laptop without it being hooked up to the external screens and see if there is a faint image on the screen or you can do this part first. If there is an image but still dark check to see if the brightness is turned down. On the keyboard you will see a sun and moon shape on the F keys just press the FN key with the key for the brightness for a few seconds if it doesn't come up you may need a new screen or power board for the laptop.
Apr 12, 2017 | Lenovo IdeaPad Z570 Notebook
I just lost the menu bar at the top of my Macbook Air- how do I make it active again?
Try and start your Mac in safe mode.
To do this, as soon as you power on your Mac hold the shift key until the screen turns black and text starts scrolling down the screen.
The Mac will check itself and then boot up (wait for it, it will take a few minutes.)
Go from here...
Oct 01, 2012 | Apple MacBook Air
EEE PC 1005P won't charge, can it be a motherboard problem?
honestly you've done everything correctly that i could think of. one last thing you could try to root out a problem with the os. is boot the computer from hirens boot disk and load the portable Windows. see if the battery is detected in hirens. then youll know if its a Windows problem or not.
personally i feel the board is the issue but it doesn't hurt to check the complete os.
Feb 26, 2017 | Computers & Internet
After shutting down my HP LAPTOP, it won't restart. If you push the "on" button, there's no response. I noticed that about 3 days before this happened, the system cannot...
- try to remove the battery of the laptop and unplug the power cord
- hold the power button for 20 seconds to drain the remaining power
- turn on the system
Jul 09, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My Acer Aspire 4520 will not come on. The light around the power button and the battery light is on but that's it. I've tried all the memory swapping, resetting the hard drive, changed the hard drive,...
Try to start it with the battery unplugged and the power supply cord plugged in. If it doesn't start that way, then you may have a motherboard problem.
Sometimes batteries go bad, and will prevent the laptop from powering up.
Did you notice any battery icon on the lower right hand bar, that had an x on it, or a message saying that the laptop was connected to power but the battery was not charging?
How old is the battery in the laptop?
Jan 14, 2011 | Acer Aspire 4520-5582 Notebook
Micron Trek 2 laptop won't start on battery or AC (NBKU375)
The lightning bolt is used to indicate an electrical problem but then, you know that already :-( Try removing the battery pack and start it from AC only; some battery types don't like to be ignored, they can have individual shorted cells.
Sep 30, 2009 | Computers & Internet
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
