Mitsubishi WD-62526,no picture,no sound,status LED blinking yellow.I checked and cleaned filter also pulled,checked connections and reinstalled lamp.
    Brigadier General:
  • 6,966 Answers
At most that the blinking indicator can tells us is that an error exist internally and what section/area diagnosis can start with. For the actual error codes to be determined you need to:
Power up the unit
Press "Device" and "Menu" button simultaneously till the power led blinks in a certain sequence. It would normally be two 92) sets of blinks.
Say one blink, pause and then 2 blinks would be 1 - 2
1 - 2 not firmware error, hardware error. powersupply
3 - 2 the lamp cover is open
3 - 3 the air filter cover is open
3 - 4 there is lamp abnormality
3 - 6 problem with the light engine (DMD problem, lamp fan stop)
3 - 7 exhaust fan stop; lamp ballast fan stop
3 - 8 overheating lamp
3 - 9 overheating DMD
4 - 1 fatal error (short circuit)
4 - 4 DVI cable/connector from FMT to the lamp engine loose/disconnected.
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 04, 2008
    Genius:
  • 2,035 Answers
I think the lamp is not installed properly or the lamp is defective.If you want you can use this link:
http://www.mitsubishi-tv.com/j/i/18326/WD62526.html?cid=152
or you can contact the company to troubleshoot: link::
http://www.mitsubishi-presentations.com/customercare/tech_support.html
  • 871 Answers
Hey there,
Does this model have PIP? If so, the trouble is leaky surface-mount electrolytic caps on the PIP board, especially any 4.7uf and 10uf components. Look carefully under these caps for corrosion/trace damage. Best way to test them is with an ESR meter, or replace ALL of them! ( Sync, both vert. and horiz., goes through the PIP board at all times, regardless of the PIP function being used or not. )
feel free to post any questions you have regarding your issue.
thanks
  • 108 Answers
According to the manual this means the Lamp cover door is open or lamp cartridge is not secure.
See Appendix F for lamp replacement information.
  • dan muggeridge Apr 04, 2008
    The manual can be down loaded (if you don't have it handy from)
    Regards
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Will not turn on
check to make sure that you didnt break the kill switches on both filter and lamp door. if one is broken you can just solder the wores together or put as jumper on it somehow.
Apr 06, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62526
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
