Question about Canon PowerShot SD100 / IXUS II Digital Camera
Black screen only on the LCD
I cannot take any pictures but flash is functioning?
  • 1 more comment
  • usbus Jun 15, 2008
    ****, I got a black screen too.. symptoms are similar.. clicks.. flash works.. black jpegs..
  • Anonymous Jun 22, 2008
    My screen is black and clicking the display button has not worked.????
  • CameraR
    CameraR May 11, 2010
    Have you tried downloading any pictures to your computer? Are the downloaded pictures also black?
I have the same problem, every other thing seems to be working fine, just black screen and black photos. argh!! wish someone would help.
Posted on Jun 23, 2008
This didn't work... I have the same problem...it makes black jpegs too.
I know its not the display...possibly a loose connection--any ideas on thisf?
Posted on May 20, 2008
Try clicking the Disp. button a few times until the display turns back to normal, it might work, if not it must be a more serious issue, this is the simplest solution I have. Good Luck!
Posted on May 17, 2008
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
There is something wrong with my flash screen. It's Black. Everytime I try to take pictures on My Finepix z fujifil blue digital camera the screen goes black, and when I go to see what I took a picture...
Flash screen? What? You mean even in pictures with flash disabled (and the flash does drag down the electronics in the thing; make a replacement using an LED lamp and circuit if you have a chance) it takes no picture and leaves you with a black LCD? Are you indeed using a good battery (they go bad gradually (depending on the case on how many times you fire the flash!)) New battery first!
Aug 25, 2011 | Fuji FinePix Z10fd Digital Camera
My ACER AT4220B LCDTV has sound but no picture. When powered on the Acer screen flashes on for about 1/2 a second then the screen is black. When connected to a computer the windows desktop flashes and then...
This tv have a 2 long boards call the LCD inverter boards.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a 2 refurbishes long LCD inverter boards for the replacement.
Dec 06, 2010 | Acer AT4220B 42 in. LCD TV
JVC LT-37X688 37 in. LCD TV. When powered on there is a brief flash of light on the screen and then the screen is black and stays black. Audio is fine and I can still use all of the remote controlled...
No lamp on LCD tv.The LCD backlight inverter board it dead,that board needed replaced to get picture back.Tries Shopjimmy.com,Ebay.com to buy the LCD backlight inverter board.It usally a long board.The refurbish LCD backlight inverter board about $100-$120.
Feb 14, 2010 | JVC LT-37X688 37 in. LCD HDTV
LCD viewer screen blacked out
Really? Your lcd screen might be damaged! take it to someone who can tell if a pixel is damaged or not.
Nov 12, 2008 | HP Photosmart R725 Digital Camera
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
Canon PowerShot SD100 / IXUS II Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
