Question about HP Office Equipment & Supplies
When installing our new Photosmart C6280 All-In-One printer, scanner & Copier. The process will not go past the alignment process. All it does is spit out a blank page, the message states to insert a sheet of white paper and press ok. But again it only spits out the blank page. We can not proceed any further, can you please help?
As the machine was only bought today I will go back to the suppliers as it will be under warranty.
Posted on Apr 04, 2008
SOURCE:
I have aHP Photosmart C6280 All-in-One Printer. Scanner.Copier. and my Computer fails to recognise the C6280. Iwould like to download the driver for thismodel of printer.
I understand your printer problem, if you are using XP, then please check to see if there are other printers on your computer that you may longer have. Go to your control panel and then click on printers. Delete any printers you no longer have.
Then go to add and remove programs and uninstall any programs associated with your HP printer.
Turn off your printer and unplug your printer from the computer.
Please go to the HP website by copying and pasting the below link into your web browser.
Select XP or other operating system, Vista or Windows 7 and download the driver / programs for your model printer, save to your desktop. Install program and about half way through the program will ask for you to plug in your printer and turn the power on. Follow the prompts.
If the installation advises that it cannot detect your printer, try another USB cable or port.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3194498&
Sep 06, 2011 | Office Equipment & Supplies
I am on my husbands computer, however, here is my problem. I had Vista Windows on my computer. It crashed and Windows 7 was installed. Now it will not let me install my printer. I have a HP Photosmart...
Go to HP's website (hp.com), click on Support & Drivers, do a search for "Photosmart C6280", click on "Photosmart C6280", download the drivers and software for Windows 7 (you'll need to know whether you've got the 32 or 64 bit version), then follow the install instructions.
Aug 04, 2011 | HP Photosmart C6280 Printer
Printer won't work manually.
Usually, you need to print a test page: go to start, settings, find printers and faxes and open it. You will see your printer. Right click on the printer and you will see a menu. Open Properties. Find General- there is a "print test page" button. Click on it. When the test page is printed, you will see some pictures: those are the steps you need to take to make your scanner/copier work. Basically, all you need to do is put the test page in your scanner (as indicated) and press scan. The scanner/copier will then do an alignment and you will be able to copy manually.
Apr 01, 2010 | HP Photosmart C6280 Printer
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
You must replace all cartridges with new GENUINE HP carts to get a sucessful alignment.
This is how HP makes their money.
Jan 15, 2009 | HP Photosmart C6280 Printer
Owners manual
You can get the user manual from this link, just sign up a account and its free so you can download the user manual for this unit http://www.retrevo.com/support/HP-C6280-Multifunction-Printers-manual/id/4357ci060/t/2/
Jan 09, 2009 | HP Photosmart C6280 Printer
Paper jam
Open the rear access door to look for paper.
Dec 23, 2008 | HP Photosmart C6280 Printer
We have a HP Photosmart C6280 All in One Printer/Scanner/copier. We want to scan to computor.The menu only shows "scan to copy" and "scan to memory card" The manual that came with the...
If possible, find the software disk that came with the printer, and reinstall. One of the options should be to scan from the scanner to the computer. Just make sure that option is selected on re-install, and that the necessary communication cables for that option are installed.
Nov 19, 2008 | HP Office Equipment & Supplies
HP Photosmart C6280 Scanner
Hi - You can download the manual by clicking the link underlined in blue below:
Photosmart C6280
See page 80:
You will need the "All in One" software for your computer:
Software
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 23, 2008 | HP Photosmart C6280 Printer
Open Questions:
77 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
