Question about Fujitsu (G281065802)
Fujitsu N Series Lifebook Laptop Keyboard Problem
I have a similar problem to one listed. I have had this problem since I purchased the computer 2 years ago. At random times the keyboard will simply jump to a different sentence when I am typing. It is very sporadic, but will happen several times a day. VERY frustrating. My husband just talked to someone with the exact same computer and has had the same problem. Can you offer any advice?
    Sergeant:
    Champion:
  • 329 Answers
What operating system do you use? have you check already the bios of you laptop, it need a upgrade.
Posted on Apr 04, 2008
I have the same problem. IU will be typing away and it seems to tab backwards or something. I returned the first laptop with this problem think it was defective but the second unit did the same thing. The worst part is that I could not recreate the problem for the shop techs. It happened on both XP Pro and Vista builds.
Posted on Apr 29, 2008
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
Nov 18, 2015 | Fujitsu Siemens LifeBook Computers &...
Why is the @ sign on the letter q
Somebody remapped the keyboard. Are you using Shift 2 for the @ sign?
Apr 06, 2014 | Fujitsu Siemens Fujitsu LifeBook P Series...
How to screenshot on a fujitsu lifebook
Use PrintScreen key on keyboard, or ALT PrintScreen. Better yet, install PickPick on your computer and use it.
Apr 03, 2013 | Intel S6240 Notebook
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
How to replace keyboard lifebook E780
fujitsu-s2110-replace-keyboard.jpg This step-by-step guide explains how to replace the keyboard in a Fujitsu LifeBook S2110 laptop.
The keyboard removal process is very similar to many other laptop brands.
1. Remove screws securing the keyboard.
2. Remove keyboard bezel.
3. Unplug keyboard cable from the connector on the motherboard
Dec 15, 2011 | Fujitsu LifeBook E780 Notebook
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
Adding memory to Fujitsu LIfebook Series A3040
You remove the access cover which is where the power button is right under the screen by sliding it to the left until it comes off.Then you push the keyboard up to the back of the laptop until it will lift up exposing another cover. You remove the second cover and that is where the ram is located.Ram is under the keyboard.
Oct 09, 2009 | Fujitsu Siemens LIFEBOOK A3040 PC Notebook
Display problem in Fujitsu LifeBook C Series(c-6631
the internal bulbs of ur monitor screen have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
Always purchase laptop or notebooks NEW or never more than 5 years old.
May 24, 2009 | Fujitsu LifeBook C6631 Notebook
Fujitsu (G281065802) Logo
793 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
