About xp installation files
I'm having a case -in a laptop with hard drive 40 gb. partitioned as 1primary with 10 gb space and rest logical with 3 partition of equal size named c,d,e,f respectively. here c is active as well as primary partition.
i wish to know if i install xp sp2 in d drive ie not the active partition and not primary partition as well , question 1. will it harm in any way.
2. where will the system files like boot.ini, ntdetect,ntldr,autoexec.bat,io.sys etc will be located.
3. in future if i happend to reformat primary partition ie c will it do any problem.
4 in future i install another copy of xp on same machine (fresh installation ) on c drive now does this installation will do any problem.
5 do both installation have their own boot.ini,ntdetect,ntldr,autoexec,io.sys,msdos.sys.
kindly give your review on any extra matter i have left in following case.
thanks.
  • rainbow99984 Apr 04, 2008
    as i mentioned in my question clearly i have no xp prior to this . i am doing the same as i wrote above acording to the question no.
    saying again
    no xp installed at first . now installing in d drive. now if possible i wish to know acording to the question numbers i asked what will happen on the way i will do.
    cause i did but not clearly understand what happend.
    so please let me know. thanks in advance.
    thanks for reply but can you plz answer by the question number to be specific.
    thanks again
    Novelist:
    Champion:
  • 236 Answers
If you are alrdy running xp on drive c which i suppose is your primary, when you try to install xp again it will prompt you and confirm if you want to either upgrade or repair. if youy choose repair it will opt you on the same location wer your OS is right now. if you wish a clean install and windows will detect previos version which wil surely find the one in your primary, select the option to install in the drive you wish to install, pressumeably D. after you finish installation, all windows files everythoing will be copied in D. you can erase your C anytime. all systems files will be in your D or where you actually reinstalled windows now. everytime you install windows it will always boot on the last installed. in fact the original systems files in your primary will be changed thus will not boot from there but the new one.
Posted on Apr 04, 2008
  • Redentor Rivera Apr 04, 2008
    sorry about the xp thing. your old system files will no longer be active soon as you install your XP. it will still be in the same location as before. your new active system XP files will be in the drive wer you will install the xp. soon as you reboot your system it will now boot XP, you can still access your primary and browse. be careful now, all the drivers of your laptop is in the original OS. if you do not have the support CD of your laptop you could get into trouble installing the drivers. unless your option to install XP is to upgrade. and if you are upgrading then it will go to the previous location of your OS, not in the specific drive you wish to install. check first your support materials for your laptop.
  • Redentor Rivera Apr 06, 2008
    2. your old systems file autoexec.bat etc... will be in the same location of your old OS in this case primary.
    3. problem with what? the OS, no because when you changed to XP or another OS, you are booting on your other partition maybe d,e f... and your OS does not need C to boot.
    4. the same situation now when you installed XP. when you are prompted to choose which drive you want to install XP, once you select C then your system will boot on your C not on D anymore. going back to the same question of 2-3, the systems files autoexec. etc...of XP on your logical partition will no longer be used. it will be the fresh autoexec and everything of new install XP that will be used.
    everytime you install your OS in any drive, all systems files will be there. but whenever you install and make use of that, the old systems files fill be renamed... the extension files that is why it will not boot up there. the system will boot with the right systems file names. Each installation will have its own boot.ini,ntdetect,ntldr,autoexec,io.sys,msdos.sys.
    in its own directory where it was installed but as i said the extension files will be renamed because you have installed a new OS.
HELP.What Happened to 40 GB Space???
You may have to try to repartition the drive, you can do this while installing windows on the disk. If a partition table is corrupted it can make windows think there is more pr less space on a disk, Ive had tables corrupted so bad on dying drives they reported 999999999 gb on a 40 gb drive. you may want to look into getting a new hard drive as well if this is occurring.
Aug 02, 2010 | Fujitsu Siemens (MHV2060AH) 60 GB Hard...
How to add free disk space in hard drive?
Use a bootable CD and use partition magic 8.2 program for this purpose. You can change any desired format without data loss and also resize without any data loss. It will work 100% and guranateed beter work.
Good Luck
Dec 01, 2009 | Computers & Internet
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
I just installed a Maxtor 6L06033 (60GB) drive in my Essential 500. Why does it only format to 32GB?
1.the max configuration for this PC may only be for 40 GB
2. you may have to format the drive in to a 2nd virtual drive 32/22
3. check the manufacturers spec to see the maximum drive it can take.
Sep 28, 2009 | Gateway Essential 500 PC Desktop
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
Aug 17, 2009 | HP Pavilion dv6-1030us Notebook
How much partition do i need on a 10gb hard drive to install windows xp pro
You need 1.5 GB minimum free disk space. Partition size is not relevant, provided you have one with that much disk space available. Best practice on a drive that size is make a single 10 GB partition.
Apr 15, 2009 | IBM Computers & Internet
MY 10 GIG HARD DRIVE IS FUNCTIONING AS A 2 GIG HARD DRIVE, ITS ONLY DISPLAYING ABOUT 2 GIG AND THATS ALL IM WORKING ON, I RECENTLY INSTALLED XP ON IT. WHERE IS THE REST OF THE SPACE? THERE IS ONLY ONE...
Since it is an old drive. It could just been formatted on 2 gig where FAT system that can run using windows OS. Just partition the rest that is remaining, activate it and then format it to make it usable. You can use third party partitioning software if you like. And before I forgot check also its jumper if setting is lock to access on 2 gig only.
Just for input.
Regards
Apr 08, 2009 | IBM (10K2059) 10 GB Hard Drive
I have an Acer Aspire 3500 laptop & want to merge the logical drive D to primary drive C as the C drive keeps filling up & I get a Not Enough memory warning coming up the whole drive is only 40gb
Download Partition Magic (or some other Disk Partitioning tool) and delete the D:\, then resize the C:\ to maximum size. Note that this is not a foolproof process and you may lose all your data - so back it up before you begin.
Secondly, 40 Gb is a fair bit of space to have filled. Have you tried backing up any data (that is not essential on the Hard Drive) to DVD's or some other external storage device, and deleting Restore Points and Temporary files to clear up some space?
In both cases, defrag the disk after you have finished.
Good luck.
Apr 23, 2008 | Computers & Internet
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
