Question about Philips GoGear SA3125/37 MP3 Player
Ear-bud problem Only the left ear-bud will play unless i push down on the bottom of the cord while plugged in.What should i do?
  • 8,596 Answers
Find out if it is warranty - get it exchanged
Posted on Apr 08, 2008
My ear buds don't work. Is there a trick I don't know?
Did you check the volume control on our unit? Have you tried your buds elsewhere? Have you tried other headphones on your unit?
Sep 10, 2015 | Apple iPhone 5c
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
The whole wire that connects the left ear bud along with the ear bud still on it just fell out of the part where the two wires come together. Is there any solution to this problem?
buy new headphones?. i think a lot better than trying to repair it. it sounds like you are talking about where both earbud wires come together at the molded connector part that splices the wires together. unless you are mechanically inclined and electrically astute, you should just replace the
Mar 25, 2012 | Bose in-ear headphones - Black with...
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
Right ear bud isn't working
i have this problem too, except it's the left side that doesn't work. i think that's because the copper wire inside broke or is severed partly. there is no way to fix it... just go buy a new one and this time try to kot coil the cords around hour mp3or ipod.
Oct 27, 2009 | Bose on-ear TriPort Headphones
The left ear bud wont work
This is usually caused by a short in the wire. The most cost-effective solution is to buy a new pair. "Shure" makes very nice ear bud headphones.
Sep 18, 2009 | Skull Candy Ink'd Stereo Ear Bud...
Same issue - right earbud volume lower than the left
yh im having the same problem good to know its not just me
Jul 08, 2009 | Sennheiser CX 300 Consumer Headphones
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Earphone problems
the longer one goes arround your neck.
Jul 05, 2008 | Sony NWZ-A818BLK Digital Media Player
Bose in-ear headphones sounds cuts in and out
Well, here's a temporary fix until you guys can get new ones. Pull the plastic stopper about halfway up the phones. Then loop the bottom of the entire headphones through the circle that the plastic stoppers create. When you have a tiny loop, pull the upper stopper down and tighten it. People said that they needed to angle the cable in a certain way, right? Well, this fixed mine for now. Just keep it in that position until you can get a replacement or they come up with a permanent fix.
Feb 20, 2008 | Bose in-ear headphones - Black with...
Philips GoGear SA3125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
