Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Power Shot SD300 card holder
Hi. Last time I solved the e18 error, i had dismantled my Power Shot SD300 and fixed this problem. But I fogot to take out the SD card. So when I assembled the camera, it showed flash card error. What can I do with this? How can I fix it by myself?
    Genius:
  • 2,985 Answers
Simply reformat the card.
Assuming that you have not damaged the internal contacts in the card chamber whilst you were delving
Posted on Apr 07, 2008
Camera shuts off after E18 error code
You have most likely dropped the camera or banged it against something while the lens was out. This situation causes the brass pinion gear to shear teeth off the plastic ring gear on the Inner Lens Housing. It may also cause the guide pins to jump their track. If this is the case the repair bill usually exceeds the value of the camera and you are probably better off selling it for parts on eBay and getting a new higher resolution camera.
Dec 21, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon Ixus 40 E18 Problem
try this link for E18 error in canon cameras for instructions
http://www.e18error.com/repair.html
pls rate me FIXYA for help
Apr 08, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Received the error code from Canon Power Shot
Just Google E18 and you will find all kinds of advice on this long standing problem
Mar 08, 2009 | Canon Cameras
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Error message E18
at my A80 the following Link solved my problem properly.
http://photography-on-the.net/forum/showthread.php?t=5700
Best greets
Martin
Jul 05, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
E 18 problem
Your first problem sounds like a defective CCD imager. If your camera was an S300 Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Unfortunately, you mention that your camera is an SD300. That model camera is not currently on the recall list. But you might want to call Canon anyways. You might get lucky as the problem sure sounds familiar to the recall (excuse me, advisory hehehe).
As for the SD500 with the E18 error, try http://www.e18error.com/repair.html
Nov 13, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon Power Shot SD300 Broken Screen
pretty easy to replace the screen, i suggest buy SD300 from ebay that has lens problem, but it is known for sure that screen is working, you might find one for $20-30, also look for SD200 you might find it cheaper and it uses the same screen as your SD300
Aug 19, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD200 E18 Error
The "E18" error code indicates an error that involves the lens unit or lens cover. The grinding noise you hear-to my regret- means that len's mechanism is malfunction. This type of problem could be fixed by professional only.
Jun 23, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Problem with my camera
Your lens is jammed, and needs to be repaired or replaced.
Sep 04, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
