Question about Honeywell Programmable Thermostat Heater
Honeywell T8001C I just noticed the display stopped working. The fan will turn on when I flip that switch, but it is the only thing that responds. I checked the fuse and everything there appears to be in order.
  • 5 more comments
  • runner12 Apr 27, 2008
    I have the same problem--fan works but the controls are unresponsive. Any solutions?
  • kgraham1 May 03, 2008
    I have the same problem. Please let me know if you find a solution.
  • Anonymous May 20, 2008
    After a power outage, we are facing the same problem as the Yuma family. There is no display showing and the only thing that seems to work is the fan in the "on" position. Let me know if any has a solution.
  • TomiQ Jun 02, 2008
    I have the same problem as the others power went out and when it came on nod display
  • Anonymous Jun 08, 2008
    I have the T8000. Fan turn on. No coolness. But no display. Have tried solution offered but nothing happened.
  • sbhelms Sep 24, 2008
    Same issue. Power outage, after power returns, no info on controller display. Checked all breakers and all is well. Fan will turn on when the fan slider is turned to "on". However, no cooling or control of programming.
  • Anonymous May 05, 2009
    My T8011R display went blank. I took it off the wall, and there is an E-F marking with a circular cut out next to it (looks like a diode or the like, not sure if it actually rotates or not). What is the E-F indicate? I can't find a switch anywhere...
    thanks
    New Friend:
Hi, take a look on amazon for replacement, here: Defy Mother Nature with our Best Buy. I hope this was helpful. Cheers
Posted on Dec 21, 2014
I had the same problem with my Honeywell T80001C, after a vicious thunderstorm and a one hour power outage, during the monsoons in Arizona. No display on the unit when the power came back on. I new the problem wasn't a circuit breaker or GFI as the fan still worked when moving the FAN switch from AUTO to ON.
The three booklets that came with the unit were of no use in solving this problem.
I removed the unit from its wall bracket and toggled the switch on the back from "F" to "E" several times and back to "F" as suggested by others. The switch position depends on whether you have electric or gas heating. "E" for electric, "F" for gas. Put the unit back on the wall…. nothing. I tried this several more times and thought that this switch toggling was all bunk, then I read the solution by "collinator" and thought, OK nothing to loose, took it off again toggled the switch left it in the "E" position for 10-15 minutes, toggled it again, leaving it in the "F" position. After another half hour put it back and it worked!!
Can't believe it, can't explain it, as the other guy said - be patient.
Posted on Jul 24, 2010
  • 1 more comment
  • Calmman Sep 28, 2010
    I got the same problem after a power outage. I followed this protocol, and my unit came back to work! Thanks for the information. It is really help! And, right, BE PATIENT is the key...
  • spdn4fun Jun 21, 2011
    Wow, this worked!! Thanks so much! I was just getting ready to go buy another one because I thought mine was fried from the power outage.
  • mmcaleese
    mmcaleese Aug 04, 2012
    This totally worked! Thank you!! Saved me a service call. Taught me the value of patience.
Hi, I had the same problem with the 8011 and lost the display after a power outage. I took it off the wall and toggled the switch on the back about 6 or 7 times, replaced it back on the wall and it worked like a champ..thanks for the info!! Heres a good site to download the owners manual for a few of Honeywell T-Stats: http://customer.honeywell.com/honeywell/ProductInfo.aspx/T8000C1002 Just go to the bottom of the screen and you'll see the download button...Helps for resetting the T-stat..
Posted on Oct 16, 2008
  • home_owner03 May 09, 2011
    05/08/2011 I am with everyone else, I do not know how or why this works, but it really works!
    Happy Mother's Day and Thank God for the internet!
Just a quick clarification for those who may have this issue in the future with their Honeywell T800 Thermostat. The display was blank following a lengthy power outage....
Checked all breakers, fuses and GFI plugs in the house to no avail.
Pulled the Thermo from the wall....toggled the switch on the back from "F" to "E" several times, making sure it was back at the "F" setting....replaced it and the display came on, but was not responding to inputs from the controls.
I pulled the unit again...toggled "F" to "E" and let it sit for 30 minutes or so....put it back on and it is now working fine!! It seems patience is key with these....
KC Minden
Posted on Aug 02, 2009
I too returned home after a 90+ degree day, power had gone out (sometime), no AC in house and no display on the thermostat. I removed the unit as others had suggested, and flipped the E/F switch. Sorry, didn't work for me. What are the E/F settings anyway? Mine was in the F position originally. BWT, I checked/reset all the breakers, etc. Now what???
Posted on Jun 27, 2008
I have a honeywell model number RTH221B.. i noticed today i have nothing on my display , i changed batteries , nothing happened , check circit brakers , looked ok... i even tryed shutting breaker n turining it bck on , still nothing.. fan comes on , but air And heat doesnt .. can anyone help ? thanks
Posted on Aug 03, 2009
    New Friend:
Thanks for all your help, it worked for me too. Toggled several times, waited around 30 min. switched to F position, attached it back to the wall and lights were on!! Praise the Lord. Thanks a lot guys!!
Jose
Posted on Oct 26, 2014
  • Jose Perez
    Jose Perez Oct 26, 2014
    Jose
I have a T8001C that was showing all LCD segments and signs lit up when I looked at it. My guess is that it happened after repeated power outages I had a couple of days ago. It has no battery. When I saw all the people talking about flipping the F/E switch and then it started working, I decided to pull the unit off the wall...it remained lit up. I just left it sitting there until I saw all of the LCD segments gone - blank screen (actually I waited probably 30 mins while watching a tv show... lol). Then I just popped it back on the wall plate. This fixed the display and the unit was working again. Hope this helps somebody. =)
Posted on Oct 28, 2011
  • Telegan Oct 28, 2011
    Just to clarify, I didn't flip the F/E switch. If you do, make sure you flip it back to its original position as it indicates whether you have a "fuel" or "electric" setup.
Tried the "toggle and wait" technique...didn't work. In the troubleshooting section of the manual, suggests to see if the on/off switch by the furnace is "on." I have my golf clubs there and must have turned the switch to off putting them away.
Posted on May 10, 2011
This worked for me too... toggled the switch a few times then waited 15 minutes...
Posted on Dec 04, 2010
I had the exact same problem with the T8001C after a power outage. So I carefully took the unit off of its base-plate mounted on the wall. The unit was held by four locking tabs: two each on the top and bottom. After I pulled the unit off, I toggle the switch in the back a couple of times and put it back in its original position. I, then, put the unit back in its base-plate while making sure that the connectors mated properly. When I put the unit back in, the display came back on and the unit started to work again.
For now, I saved $169 on flat service from one AC repair company.
Give it a try, it worked for me.
Posted on Jun 06, 2008
  • mccamck Mar 26, 2011
    We have the T8001C and it keeps running, it will not shut off, there is no display on the thermostat, im using way too much power with this thing just running running running HHHEEEELLLLPPPPPP! Ooooo and we took it off and toglled it like everyone else said and to no avail it did not function for us. : (
My display on Honeywell T8001C Thermostat came back on and working again after I pull the unit off from its base-plate carefully, toggle the switch in the back of the unit a couple of times and back to its original position and put the unit back in its place making sure that the mating connector lined up properly.
Either toggling the switch did it or re-seating the unit did the trick.
For the time being I saved $168 flat rate service call from one repair company.
I woke up one morning and my thermostat was blank,the thermostat is a honeywell T8011R and does not require batteries.My system will not turn on,I need some suggestions on what to do to fix this problem.
Posted on Oct 18, 2008
How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jan 10, 2015 | Honeywell T8001C1019 Programmable...
Power company had to shut power off to my community. When power came back on several hours later its still a blank display and does not work. I have turned off and on every circuit breaker I have in my...
cefb7e0c-979f-4b1a-bff6-c84fcbc4c9cf.pngYou will need a meter and test for 24 volts at red and common, if present, you next need to check at yellow and common and green and common, green being fan and yellow being ac outside.
I suspect the transformer is not providing the 24 volt control power to the stat either due to the high voltage or a low voltage fuse has blown on the board usually a 3 amp auto type, beyond this I am unable to offer much help .
Aug 25, 2013 | Honeywell Programmable Thermostat Heater
I need my t8001c Honeywell to turn the heat on and stay on. Its getting stuck on a hold position but then it goes to away or leave and it wont stay on. I have several manuals for this t8001c and they all...
You are setting the temperature on temporary hold. It stays there until it reaches the time of the next programmed sequence which is away or leave and it jumps back on the program. If you want it to stay all the time where you set it you can push the setting up to the desired temp and push hold. It will stay there permanently until you push run which will put it back on the program if you want. Or just push set and program the whole sequence the way you want then press run.
Jan 11, 2018 | Honeywell Programmable Thermostat Heater
My 9 year old Honeywell T8001C has no display. My FAU AC power breaker is not tripped. I tried a new Honeywell RTH2510B and a RTH7500D but the Fan does not come on with either of the new units after...
This is why battery powered tstats are misleading. The battery provides the power to the tstat but your unit is not providing low voltage in order to run. Air conditioners are controlled by relays and contactors. This means your unit constantly has high voltage going to it but each component runs through a relay in order to turn on. These relays are energized by the low voltage that runs through your tstat. Your tstat is not getting this low voltage. Either your float switch on your drain line is tripped, your blade style fuse is blown on the secondary side of the transformer or your transformer is bad.
Aug 08, 2017 | Honeywell Heating & Cooling
Hi, we have a Honeywell ducted heating thermostat model t8602c2069. It has recently stopped working. This display panel is working so it's not the batteries, however when we turn it on heat does not come...
We have exactly the same problem as dmlauder! (posted 6th September)
What does the square symbol mean?? We have to keep resetting the outdoor heating unit...it works for a few minutes then stops
cate
Sep 06, 2010 | Honeywell Heating & Cooling
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Display and buttons not working
replace t-stat if there is power to inside unit
Oct 22, 2009 | Honeywell Electronic Programmable...
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Honeywell T8011R
Check for either an in-line fuse in the heating unit or a fuse on the control board also in the heating unit.
Nov 06, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
11,175 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
