Question about HP Compaq Business Notebook NX9010
Bad Harddrive I was asked to fix a Compaq nx9010 for a friend. The only thing it would do at the time was say, "Operating System not found." 1. I removed the harddrive and attached it to a desktop machine. Not recognized. 2. I ordered a new harddrive installed it and loaded WinXP. No problems with the install until the machine was supposed to boot to the harddrive. "Operating System not found" The XP installation still sees a 28 GB disk with an XP installation on c:\windows. The BIOS hard drive self test says, "NO IDE Device." 3. I flashed the BIOS upgrading from F.21 to F.25. No change. Any suggestions for step 4?
  • 4 more comments
  • Anonymous Apr 11, 2008
    Sorry, I've been busy shoveling snow.
    digiteyes: Both drives are IDE.
    pagebor: When you say check the cables I assume you mean inside the case. I haven't opened the case yet. I do not have much experience opening notebook cases. I removed the twenty odd screws on the bottom of the case. There was still something holding the case inside and I couldn't determine what it was.
    The notebook is several years old so I assumed it is IDE. How can I determine IDE Vs. SATA?
  • Anonymous Apr 12, 2008
    Yes, the BIOS settings. I had looked at the IDE setting [NONE] several times not realizing that it was changeable. As soon as I changed it to [AUTO] Voila! Thank you!!
  • jamps7 Mar 12, 2009
    say operating sytem not found
  • protector1 Apr 01, 2009
    i have the same problem with my portable laptop he doesn`t recognize my operating sistem and i can`t enter in the bios he is..
  • digiteyes May 11, 2010
    Are the original and new drives IDE or SATA?
    Scholar:
  • 110 Answers
Can you just clarify that you installed XP with the new IDE drive installed in the notebook and that you have selected disc 0 in the bios as IDE and that it is aslo set to boot from that drive?
What you are describing also fits the symptoms of installing XP on a SATA drive without installing SATA drivers first. (XP doesn't install SATA drivers, Vista does.)
So this does sound like a bios setting issue
Posted on Apr 11, 2008
  • digiteyes Apr 11, 2008
    I wasn't saying it 'is' a SATA drive, just that the symptom you are describing is common when trying to install XP on a SATA drive.
    If I recall correctly, that model notebook did ship with an IDE drive.
    The type will be on the label on the drive.
    What is the make/model of the new drive you installed?
    What are the current bios settings?
    Genius:
  • 2,785 Answers
Please check your cables and try with new one.check the bios setting
Posted on Apr 04, 2008
SOURCE:
I need bios password for compaq nx9010 plese help
y this procedure. It very serious problem. For someones...
To remove that password there are few steeps:
0. remove AC power
1. remove system battery (primary and multibay if present)
2. remove harddrive from harddrive bay
3. remove Multibay Devices from multibay
4. remove small round battery pill 3.3V, located under a cover on left side of touchpad. Remove cover gently (is no need to remove keyboard, but cover is removable with some power...) Delicate unplug small conector with cables leading to battery,
5. wait 5 minutes
6. connect AC power
7. Turn on computer unit (BIOS gets a few errors = date, time, mismatch etc. no need to panic, if everything is ok then get into computer setup pressing F10, change existing setup values as needed, if ok power down computer.
8. unplug AC power
9. Plug small battery into motherboard
10. install Hdd and multibay devices
11. Install system batteries
12. Power Up computer, there could be no password anymore
Jul 03, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
Nx9010 notebook coming up with disk read error dont have recovery disc this is my granson's computer
it`s very possible to be a hard drive error, the main thing what you can do is to try to install the operating system over the old one if that goes ok it means that you had a premature shutdown and the files where corrupted if the problem persist it`s a hardware problem.. solution is to buy another harddrive
Mar 13, 2010 | HP Compaq nx9010
Compaq nx 9010 CPU and RAM upgrade
why do you put cash on such an old horse? P4, wow... with a square screen no less.
the PC has book at HP, many , one is service,
and shows all processors offered for the time it was made.
read that yet?
no you cant add more ram.
it also uses ram that is not made now. making this harder, to the max. ask , Frankston memory this question.
for $20 at Goodwill buy one far newer, and avoid this thing,
sorry but that is best, why mess with an old compaq relic MOBO.?
the laptop only runs laptop CPUs.
why do it. name 1 good thing about old laptops?
Jan 19, 2010 | HP Compaq Business Notebook NX9010
HP Compaq nx9010 CD drive replacement
You are correct.
The screws for the dvd drive is under the keyboard.
there should be 2 tabs one above the f4 and the other above f12 take a regular head screw driver put it where those tabs are and gently pull down towards the touchpad and the keyboard should come up easily.
Now under that keyboard in the center you will see a opening and inside that opening you will see 1 philip head screw remove that by turning counter clockwise.
Right below where you removed that screw you will see another opening which has another philps head screw in it.
Remove that screw counter clockwise and the dvd rom should pull straight out with ease.
To put it back together just reverse the steps.
If you need further assistance do not hesitate to ask.
Dec 03, 2008 | HP Compaq Business Notebook NX9010
Want to increase memory above 1 gig. compaq nx9010
You may have incompatible memory module. Just put in one memory module in at a time to see if it boots up, this will determine which module was not compatible.
Nov 15, 2008 | HP Compaq nx9010
Remove floppy drive compaq nx9010
You can try the link below. It should have a breakdown diagram. If I may ask why, I'm a computer tech, and I've only used my floppy drive two times in the last three year, and that was to make a bios flah for a couple of ancient machines. Your laptop is relatively new.
Jun 24, 2008 | HP Compaq Business Notebook NX9010
HP Compaq Notebook nx9010
Hi, I can help you with this. What operating system are you trying to load?
Sep 27, 2007 | HP Compaq Business Notebook NX9010
HP Compaq Business Notebook NX9010 Logo
213 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
