Question about Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200)
  • 3 Answers
Assuming that you are plugged into your router and it has dhcp enabled...
go to start menu --> run --> type "cmd.exe" in the text field (a black window should pop up) --> in the black window type "ipconfig" (it will display your current network settings) --> look for where is says "Default Gateway" as the number to the left of it is your routers internal ipaddress
Posted on Apr 04, 2008
My company provided me wired internet using Paradyne 6381 wired modem. it works fine. I have D Link 2640 T wirelss modem + router available with me. Please advise me how do I connect available D link 2640...
Since your D-Link 2640 is a modem + router it may not work the way you intend.
You need just a wireless router without modem.
Run a small Ethernet patch cable from your Paradyne modem into the WAN port on your router, you can plug your existing Ethernet cable into one of the other LAN ports on the router, then access the router setup using the computer connected to the Ethernet cable using a browser and putting the router's IP address into the address line of your browser. It will most likely be or
Once you have configured the Wi-Fi router you will have your wireless network. Full instructions should come with the router.
Routers are available for as little as $29.95 but expect to pay closer to $79.95 for satisfactory speed and capability.
Oct 23, 2017 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Hello there, need to know how to config a phone line modem Zhone 6381 I guess its called the Zhone 6381-Ax Router. I happen to prees the reset button and losst the programed IP. how can I go about...
To configure your router, make sure you are connected to it first, open your web browser. Ignore any error about lacking a connection. Type the default IP address ( into the Location field of your browser and press the Enter key. The following screen appears.
The default user name is Admin and the password is Admin. Both are case-sensitive.
Note: You should have your PCs configured for DHCP mode (if your router will be), and have proxies disabled on your browser. If you see a login redirection screen when you access the web interface, verify that JavaScript support is enabled in your browser. Also, if you do not get the screen shown above, you may need to delete your temporary Internet files.
The first screen that appears after the log in screen is the Home page.
From this screen you can configure the LAN and WAN connections, configure the router's security, routing, and filtering, access debugging tools, obtain the status of the router, and view the online help.
From here, go to the Setup Tab and click the New Connection on the left.
Input your numbers and don't forget to save.
Hope this helps!
Dec 21, 2010 | Zhone (6218-I2-200) Router
What is the default ip of the paradyne modem6381
The default ip is :
The default User-name and Password is : Admin
Some model came with default ip
Subnet to use is
Ok make sure you are using an ip address with the same range.
That is you can set your ip 192.168.1.x where is 2 to 252
ok try this
Jan 22, 2010 | Paradyne 6381 ADSL2+/ReachDSL Router...
What is the ip address of paradyne 6381 a3 300 router
To configure your router, open your web browser. Type the default IP address ( into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is
The default password is Admin
Jan 08, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
What is the IP address, Username and Password for the 6381-A2-200? Thanks for your help!!
The IP number is:
The login info is UserID: Admin (case sensitive)
The password is Admin (case sensitive)
Also here is a link to the users manual:
Good luck and if you found my solution to be helpful please rate it.
Apr 02, 2009 | Paradyne ADSL/R 6381 Router (6381-a2-200)
How to configure my paradyne 6381 router
Go under LAN setup and enable NAT and Firewall services. Then go to LAN configuration to enable the dhcp server. Set the Start IP range and ending address.
Feb 24, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Using both USB and Ethernet port to connect to the Internet
Hi; I have used it with both ethernet and usb connections at the same time. I have never used the bridge, but I use it at home.
Try this ( I have XP SP3): Right-click on the monitors where the clock is (lower right corner), select "Open Network Connections". Go to the LAN connection and r-click "Properties". On the "general" tab select "Internet Protocol (TCP/IP)". There you select "Obtain IP address automatically" and "Obtain DNS server automatically" then click "Ok" until exit. Either Shut Down or Restart the PC. Check if this work.
Jul 19, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Trying to set up pptp on a Paradyne 6381
I have modems 6381-A2-200, sw ver.03.00.10. This model does not support pptp-connection.
Dec 06, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Cannot access my modems home page.
Nore than likley that is the default LAN IP address that came with the device. It has probably been changed during the initial setup. A quick way to tell is go to your start button/ select run / type in the run box CMD / this brings up a dos shell in the dos window type IPCONFIG and hit enter.. Note your IP address and your default gateway.. " the default gateway is your device in question. make sure your IP address matches your gateay with the exception of the last 3 octects. so it should read something like this
IP Address
Subnet mask
My guess is that your not on the "1" network but the router is handing out a different range of address if that is the case in the dos window type ping (the ip address of your default gateway)
like so ping 192.168.X.X where X = the octet values of the default gateway listed in the dos window
If it replies then your talking just fine you are simply trying to access your router via the wrong IP so take the IP of the gateway listed from the ipconfig command and put that number in your browser.
If this is not the case then we need to go in a different direction with this.
Nov 25, 2007 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200) Logo
129 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
