Question about Apple iPod MA446LL/A MP3 Player
How to fix the troubled monitor?
The LCD doesn't have any display even if theres power? Why? How to solve this problem?
  • Pik380 Apr 18, 2008
    Yes but mine is a little bit diferent sombodey sat on my ipod and the lcd screem appears to be broken from the inside on the outside there is no crack but on the inside there is and i can hear the songos it wolrks perfectly except for the screen but i dont know how to open it can u help me i woul really apreciate it.
    Problem Solver:
  • 12 Answers
The cable that connects the LCD to the system board of the iPod could have come disconnected. You may try to open the unit and clip it back in there.
Posted on Apr 15, 2008
SOURCE:
Hi, I have a asus VW192DR lcd monitor but it cannot open properly, only mixed colors, is there any chance that i can fix it on my own? pls help.
ASUS DISPLAYS are pretty FUZZY, HARD TO REPAIR but also HD and VIVID. ASUS DISPLAYS are usually HARD SEALED from the inside. Try paying it a rest and RESTARTING . Doesn't work? , DETACH the STAND to make it easy to work. The SCREWS to OPEN an LCD MONITOR are usually near the VGA/DVI/HDMI CONNECTORS. HOPE THIS HELPS.
Sep 08, 2012 | ASUS LCD Monitor
Aadab: when the moniter ON after few second the moniter is does not give display and when we on and off the moniter so then the picture displayed why this problem is occure.how i recover it.
That is because the settings on the power are set for the monitor to go to sleep if not in use.. It is a very quick and easy fix.. Just right click anywhere on the desktop that doesn't have any icons, the display properties box will appear, then click on screen saver under monitor power click on power, there you could set the monitor never to turn off... Let me know if this solved the problem and good luck..
Sep 09, 2011 | Compaq Presario 5000 PC Desktop
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
Sir/Madam im shiva from chennai , i have acer AL1713B lcd monitor , but my prob is when i connect the power cable the led light is working , but display is not working. how can my solve this prob?
Dear Sivakumar,
please try to remove and plug VGA cable back again to the monitor. and press the menu button in front of monitor if it doesn't giving any message in monitor it means that the control card inside the monitor is faulty.for fixing that you have to contact your local service center.
Thanks
Jun 18, 2011 | Acer AL1713 17" LCD Monitor
When I try to turn the computer on, battery light flashes four times but computer will not turn on. This happens even when i have the plugged into the outlet
Hi nancy jac719,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 09, 2011 | Gateway M-1626 Notebook
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
Dear sir, my lcd monitor 17"
> after getting Internet connection of my PC, that trouble came.
That probably has _NO_ affect on your LCD monitor.
You could either:
* live with the problem, spending NO money
* spend $50 to $75 for a TV/audio/video technician to try to fix it
* spend $50 to $75 to buy a used 17" LCD monitor
* spend $100 to $150 to buy a new 19" LCD monitor
Nov 12, 2010 | Acer Computers & Internet
There is no image on the screen at all even when its all set up
Is it that the when you power on the lcd monitor, the led power button powers on but no display? if it is, the means the picture board of your lcd monitor is malfunctioning.
It could be that the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | Polyview S17E 17" LCD Flat Panel Monitor
LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
Jun 08, 2009 | LG L192WS LCD Monitor
I have trouble of my desplay, power work ok but can not display any thing
hey. there is a inverter in LCD that makes view brightly shinely so you can see everything on LCD. anyway. if the inverter breaks down you get black screen. even inverter is working you get blanc screen you need to check LCD DATA CABLE that it not possible to reach it for you. i advise you to get the Service if you have warranty
have a good day.
pls rate this.
May 28, 2009 | HP Compaq Evo n620c Notebook
Apple iPod MA446LL/A MP3 Player Logo
29 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
