Question about HP OfficeJet 6110 All-In-One InkJet Printer
Cannot Align HP OfficeJet 6001 Printer
I have an HP OfficeJet 6110. When trying to print it makes an awful grating noise. Have replaced both color and black ink cartridges and tried to align w/ maintenance feature to no avail.
Cannot print.
  • chrissnee Apr 05, 2008
    won't feed paper or print also does make grating noises from time to time. can it be resolved or fixed.?
  • Anonymous Apr 08, 2008
    Whenever there is a power outage (regardless how long) if the 6110 is on it shuts down and turns back on. Then it "grinds for several minutes before telling me it has an error and to turn it on and off.
    This has been going on for years. My only solution (besides shooting the printer) is:
    1. I unplug the printer and plug it into another wall outlet
    2. I also disconnect the printer USB from the computer
    3. The I turn the printer on.
    Sometimes it works first try -- othertimes it takes several trys.
    I make a point of turning the printer off when not in use. Power outages are a nightmare!
tom19511
  • 1601 Answers
SOURCE: hp officejet 6110 all in one printer
try this:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en
Posted on Nov 12, 2007
shaggyrat
  • 1224 Answers
SOURCE: HP OfficeJet K60 Align cartridge problem
ok the link i put here for you is very long page of typing so for hp
i found you the link to go threw the alignment process
sorry i cant type the whole page for you but the link is here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=59273
Posted on Jun 13, 2008
Inkworks
  • 87 Answers
SOURCE: OfficeJet G85xi cartirdges will not align
Could be one of two things....
1 - you may have bad cartridges (usually the color)...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...first replace color cartridge with a HP Brand cartridge
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Posted on Nov 06, 2008
  • 25 Answers
SOURCE: HP OfficeJet 6110 xi Self Test "Align Cartridge" Failure
Hello there,
Try cleaning print cartridges from HP toolbox
or reset process
Please see note at bottom re: powering on and off
1) If you know you are going through the re-set process. Ensure there is nothing in your printer que already when you want to power on again.
2) Plug printer/scanner directly into the wall, not a power bar or UPS... Read at one point, it has something to do with the electricity (KW or Voltage or Amps) factor and power requirements to the printer/scanner. However was very technical and don't remember enough details to explain properly, sorry... Anyhow, directly into the wall.
This is what has worked for me. Got original re-set process of solution from sillygirl.
3) Disconnect all cables from printer.
4) Clean the glass on top with alcohol and cotton swabs.
5) Then go through the reset process (press # 6 while plugging the power back into the printer).
6) If you have the CD for your printer it doesn't hurt to put it in your CD carriage in case your printer is looking for files or drivers. If CD starts to go to a un-install or full re-install just cancel and leave in carriage.
7) Sometimes helps if you first plug printer in.
8) Re-boot pc before powering on printer. Once re-boot has started and PC will start to look for printer.
9) Power on printer (press # 6 while plugging the power back into the printer to re-set).
10) Watch for point where your printer icon usually appears and plug the USB into the PC.
_____________________________________
11) If this does not work then take the printer apart and clean the underside of the glass as well. Unfortunately need to go through re-set process again. May need to buy a set of screw drivers for removing the glass. They are different. (Torx)
12) In another solution it states - you must clean all the mirrors inside the scanner assembly q-tips work well (black box closed with two locks) also the lens and the delicate spaghetti-like lamp. Generally this works... Not everyone has done this part but worth a try when the printer is already open.
13) There is a black and white strip at that end of the scanner. Check to ensure the strip is there, in tact and placed correctly. This is what the scanner carriage aligns itself with.
Just so people know. I have posted solutions to this before that have worked for me. However, I really do think this comes down to a driver issue (do we all have XP, mine is actually XP Home Edition). Since HP no longer updates these printers not sure if we will ever see a driver that works perfectly. Once you get it going again it will all work great. The problem lies in powering on and off. Once you get it going without the scanner carriage jamming, leave it on! Even in the case of a power out I usually have to re-set again but can get it going, eventually (it can be very frustrating). Sometimes need to re-boot PC and plug USB into the PC while booting up and just about to look for your printer. This is to ensure it finds the printer/scanner. Also, when really desperate uninstall and re-install the hardware. Sometimes can try for quite some time to get it working again and eventually have to just leave it off for a few days then can get going again afterwards. Not sure if this has something to do with memory.
Posted on Feb 28, 2009
POCBM
  • 121 Answers
If machine does not print the colors it cannot align. Try changing the color and try again
Posted on Apr 03, 2009
My HP Officejet 4500 keeps telling my to align my printer cartridges and I have done it several times. After I align them and print something it requires me to align them again.
Try removing the cartridges, closing the printer, and disconnect the power. Let sit for at least 10 minutes, then hook up the power, wait until it stops making noises, the reinstall the cartridges, black first, then color, and if the alignment comes up again, press cancel. This should remove the error.
Sep 30, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 Printer, add wider paper size. Also align cartridge keeps appearing even after I've pressed enter and the process keeps repeating.
Press the enter key and hold it while you press the menu button. That will make the align message go away, but if just one color is missing it will always fail the alignment. The paper size is chosen in control panel and printer properties, printing preferences.
Feb 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My HP officejet 6110 all-in-one will not print. It keeps saying to align cartriges which i've done several times.
If you do a test print and any color is missing it won't pass alignment and keep giving the error. If you're happy with the printing, when it says press enter to align, press and hold the enter button and press the menu button. The error will go away and let you print.
Feb 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My printer stopped printing
your senser is off you have to tak it in for minor repairs
May 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP officejet 6110 only prints in black and white
Every time I try to print I get a message saying that The Spooler service is not running, what should I do?
Feb 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 printing trouble
Is the yellow color OK ?
Some color is missing, you may change color cartridge if black is OK...
Nov 26, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
166 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
