Question about Toshiba Gigabeat MEG201 MP3 Player
Toshiba Gigabeat 30gb
We had a ton of music downloaded from our CDs onto our gigabeat. Have had no problems until now. Just turned it on and it says nothing is on it. I still get the start screen etc. but nothing comes up under music. So, I tried to get the radio to work, it just gives me the "circles going around" and never proceeds to the setup screen. Does this happen when I maybe need a new battery or have I lost everything. Thanks for your help!!
    Top Expert:
  • Toshiba Master
  • 30,517 Answers
If you stored music on a hdd it should be safe. If all else fails, remove the hdd and connect via usb to a computer to retrieve the music.
Posted on Jul 03, 2017
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: Driver files for Toshiba Gigabeat MES30VW
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
SOURCE: Gigabeat room fails to recognize my Gigabeat
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Posted on Dec 29, 2008
SOURCE: Gigabeat Room Can't Detect Gigabeat on Vista
The key is to have the GB watcher run under XP mode and administrator rights. When you start up the GB Room right click on the program and run as administrator. It runs every time for me. I have the F20.
Posted on Apr 10, 2009
  • 272 Answers
SOURCE: Is transfer from Gigabeat to iPod possible?
There are programs like sound taxi that will do it easily but they do charge for them. If all of the files are on your computer just add them to iTunes and they'll all transfer to your ipod. If not just transfer them from your Gigabeat to your computers music file. Add the file to your iTunes and then sync your ipod to your computer and all of your songs will be on your ipod. Unfortunately without paying for a transfer program you will loose all of your playlists and organization files.
Posted on Jun 01, 2009
SOURCE: Need Firmware for Gigabeat MEGX30
no system found on hdd
Posted on Jul 29, 2009
Can you transfer itunes music to the toshiba gigabeat?
Hi Gladys M Ortiz
Yes you can transfer your music to your toshiba gigabeat.
But you will have to convert the format first.,because Itunes uses a ACC format...you will need a WMA or MP3 format to play on your MP3 player.
Go to the following webpage and download your FREE format converter.
Please take time to rate me
Bud
http://formatoz.com/
Oct 16, 2012 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat Touch Controls broken - need to transfer music to iPod
remove front cover on Gigabeat F40, remove battery. on back of battery a spacers remove those and replace with thinner spacers. I used hi quality insulation tape three layers of and stick back onto battery. Install battery again and it will have fixed the problem. Did it with mine
Jun 15, 2012 | Toshiba Gigabeat F40 40 GB MP3 Player
I would like to copy or remove music files from gigabeat to my pc.
plug in the ipod, go to my computer and double click your ipod icon, go ta music, and then copy and paste what you want to " my music"
May 29, 2009 | Toshiba gigabeat MES60VK Digital Media...
transfering is not a a problem its a player problem have  you ever format your mp3 player?
Dec 16, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba gigabeat 30gb-multimedia player
Sometimes when the Gigabeat's battery dies out fully with no life in it, you cannot recharge it via USB. You must use the AC connection to charge it. If you do not have the original charger, you can use a Sony PSP charger.
Nov 20, 2007 | Toshiba gigabeat S MP3 Player
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEG201 MP3 Player Logo
75 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
