Question about Polaroid i832 Digital Camera
How do you get rid of card locked message on Polaroid T830?
Just bought the camera, inserted a sd card and got above message...
  • 1 more comment
  • vinnie91911 Apr 04, 2008
    Thanks for the response but tried the slider and even added a little tape as their site suggested but no luck. Sending camera back as defective.
  • ljimenez May 07, 2008
    same problem, card locked wont allow a picture to be taken
  • Anonymous May 16, 2008
    Same problem and the SD card is not locked...I have tried 3 different SD cards
    Scholar:
  • 110 Answers
SD cards have a tiny slide tab on the edge of the card.
This is used to lock the card, so you can't alter the contents.
Slide the tab to unlock the card.
Posted on Apr 04, 2008
SD card erases files when turned off
I think there is something wrong with your camera or the memory card, you had better ask official service for help. Besides,even if the photos are deleted by some error, but they are still in the SD card as long as they are not overwritten. get more here: Photos Recovery
Apr 15, 2013 | Polaroid T830 Digital Camera
Not saving pictures
If you are recording images to SD card memory, then try reformatting the SD card using your camera, or computer.
Mar 05, 2011 | Polaroid T830 Digital Camera
I have a polaroid dvf-720 brand new and trying to record and 2mins and it says memory full? i dont understand,and i have a memory card that says card error,need help or im in trouble with the wife!
Ok so I have the same problem I went out and purchased an SD card...but it doesnt work. So I called Polaroid and you need to purchase a CLASS 6 SD card of 2gb or more for it to work properly...figures it does not say that in the manual.
Dec 25, 2010 | Polaroid Cameras
How do you unlock card locked
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Sep 09, 2010 | Polaroid i532 Digital Camera
Card locked
Hello
Kind regards
Andrea
Aug 28, 2010 | Polaroid A500 Digital Camera
How do you get rid of card locked message on Polaroid i832 when there isnt even a card in it , just internal memory
It's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 01, 2009 | Polaroid i832 Digital Camera
SD Card Locked; Tried formatting SD card still no luck
There will be a small slide switch on the SD card u need to just slide that switch on the Opposite side that then insert it to the camera it will work fine....... Good Luck
Jan 19, 2009 | Polaroid i830 Digital Camera
New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Jan 09, 2009 | Canon PowerShot SD600 Digital Camera
Re:sd card
The SD card has a "lock" lever on it...make SURE it is in the "unlock" position.
You might also try using an SD card reader. These are VERY inexpensive on Ebay- but your computer has to have Windows 2000 installed for these readers to work.
May 04, 2008 | Polaroid I533P Digital Camera
T830 flash rom
I to all, sorry for my english. I have resolved this problem, with the PocketLOOX8xxFlashTool.exe. The tool first try to connect to the T830, then it show you how to reset the PocketLoox to reflash it. The sequence is:
1) Reset by pressing Power Button + camera button + factory reset; 2) insert the usb cable in the T830 or insert it in the docking with the Power Button + camera button pressed. When you insert the usb cable, on the screen it show a new message "New USB download mode". Now PocketLOOX8xxFlashTool.exe can connect to your t830 and reflash it.
Good luck
Giancarlo
Sep 16, 2007 | Fujitsu Siemens Pocket LOOX T830...
Polaroid i832 Digital Camera Logo
219 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
