Question about Cameras
Sony Cybershot with lens not opening/closing
I have a sony sybershot DSC-W30 and it was dropped resulting in the lens being bent slightly stopping it from opening and closing properly.
Any suggestions as to how I can fix this? Or is it lost
  • leah_travis Jun 28, 2008
    Hi there, I have the same issue. Dropped while it was open and bent the barrel. Opened and closed a few times initially but now the camera won't turn on at all. Can this be fixed or should we invest in something new??
PEye2000
  • 10 Answers
SOURCE: Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
Posted on Mar 26, 2009
SOURCE: when turning on power lcd says acess ,lens opens
I had the same problem. Your focus is stuck.
Try to free the focus from whatever (sand, dust, etc.) by hitting the camera. Start gentle, and if it doesn't work, hit it hard...the DSC-W30 is very rugged , that was my experience!
Greetings from Germany and good luck!
Posted on Aug 07, 2009
welcomejee
  • 10594 Answers
SOURCE: E:91:01 Error
E:91:01 is error code related to Flash Circuit abnormality. It requires qaulified technician to fix and such person would be available at nearest Sony repair shop.
Posted on Jun 03, 2008
  • 4090 Answers
SOURCE: Sony Cybershot dsc-w110 won't turn on ?
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help++++Thyanks for usi9ng FIXYA
Posted on Sep 28, 2009
Testimonial: "Thanks Man.... But before going for compressed air, I blew out some Air from Mouth, and then slapped it against my palm,It Worked,Thanks Man :) ThankU"
SOURCE: Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Posted on Mar 02, 2010
My camera sony cybershot DSC_W30 is fall down in sand and shutter can't open
Here is a tip that I wrote about How to get a Digital Camera Lens to work again
Steps to Repair a Digital Camera Lens
heatman101
Apr 26, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
The lens for my sony cybershot dsc-w310 digitial camera won't open completely.
It may have had an impact or a bit of grit/dirt may have lodged in it, try a tiny drop of sewing machine oil on a Q-tip and gently lube the lens protector
Aug 01, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Sony cybershot model DSC-W30
Sony Camera Website:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCW30
Feb 03, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Shutter problem with a sony dsc-w30 camara
Make sure the battery is strong and not failing you and that the extending lens cover parts are clean. You may have gotten something in there.
Dec 24, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Digital camera
Mine is a bit different- Mine turns on to the opening "Cybershot" screen, opens and shuts about 6 times, and then says "Please shut off and then on again" or something. AAH!! Im a photographer! HELP!
Nov 08, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
DSC P52 cybershot camera
I cannot provide the answer but i think it may have something to do with the shutter mechanism. When you dropped it, something inside the mechanism may have bent or stopped. Don't take the camera apart yourself, take it to a specialist such as an electronics store. I hope this helps. Good Luck!
Sep 11, 2007 | Sony Cybershot S650 Digital Camera
Cameras Logo
215 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
