Panasonic PT-47WX54J shut off - LED blinks 3x
My Panasonic PT-47WX54J CRT Rear-Projection television just shut off, and when I press the power button the LED blinks 3 times. It is about 4 years old, and this is the first problem I've had with it.
  • Bo Darville Apr 04, 2008
    Please post the link. I think I'll attempt to fix it.
    Thanks for your help!
  • edesfandiari Jul 18, 2008
    I have a slightly different problem with my PT-47WX54J. The power LED
    blinks 5 times between pauses. I have contacted Panasonic and all they
    can tell me is to contact a repair shop. They insist there in no code for
    number of blinks. Any idea what 5 blinks may mean?
    Ed
  • 8,617 Answers
Your convergence ICs need to be changed. 3 Blinks is a convergence error. I can post a link where you can get new ICs and they include free instructions with pictures so you can do the repair yourself, they also offer instant messaging with a tech while your doing the repair thats a free service when you but their replacement parts. Let me know if you would like the link.
Posted on Apr 04, 2008
  • Sonny Berry
    Sonny Berry Apr 04, 2008
    Here is the link. If you send an email to them while at the site they will tell you what STK number ICs you need just post your model number.
    http://servicemanuals.vstore.ca/
SOURCE:
Panasonic power led blinks but no picture
The model indicated is a rear projection crt (picture tube type) set.
Count the number of blinks and if you have to: uplug the set and try to turn it on again---most will blink a error code and the most popular are a series of 3 blinks, a pause and 3 more blinks etc.
Let me know the number of blinks and I will attempt to point you to what is wrong.
SD TECH
May 02, 2010 | Panasonic PT-47WX49 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47wx53 just shut off
Your convergence ICs have failed. Thats what causes the led to blink three times. The PT53WX53 convergence repair kit from www.tvrepairworld.com will usually repair that issue. The kit also contains the CD with detailed repair instructions.
Apr 01, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic pt 4743g that just shut off. I
Thats the error code for the convergence circuit shutting the set down The PT4743G uses the PT53WX53G convergence repair kit which is available from www.tvrepairworld.com the kit contains the parts and the CD with detailed repair instructions.
Nov 21, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Tv shutting off
when it shuts off, press the power button and see if the power led blinks and if it does let me know the number fo blinks. Please respond to this same post when replying.
Aug 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Pt47wx49e
Check resistor r517 if burnt replace with a carbon resistor 10k at 1/4watt.
Jul 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Apr 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
302 people viewed this question
Top Televison & Video Experts
Ekse
