Question about Hobart A200 Stand Mixer
Mixer has just stopped
Model A200T. Mixer has just stopped working. The guard that goes in front of the mixer bowl does have a plastic piece that has been broken off. Could this be a safety switch of some kind? The mixer drive rotates so gears are not jammed.
  • 68 Answers
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525$File/F-19357%20(05-95).pdf
Posted on Apr 25, 2008
  • 1 more comment
  • jsouthrest Apr 23, 2011
    how do you access this switch to wire around it. i dont use a bowl on my mixer and dont want to spend 400 bucks for a guard that i wont use at all, thanks so much!!!
  • Brian B Sep 12, 2012
    Older mixers have a piece wich loks like a bolt coming out that make contact with a metal tab on the guard. You can by pass the safety switches by taking the entire top of the mixer off and wiring the grounds together. This is unadvisable but easily accomplished.
    Take the 2 bolts on the front of the mixer head out as well as teh 2 large screws from the rear of the mixer head. There are 2 safety switches in this area. One for the mixer guard and one for the pedestal that makes contact when the bowl is in place. These can actually both be bypassed by wiring all 3 black wires together. This is very in-advisable though, especially if it will be used by multiple users
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
May 07, 2016 | Food Mixers
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
My h 600 will only run when i hold the start button as soon as i let go it stops
If it has a bowl guard on it then the problem could be either the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then the side switch on the contactor is the problem. If it has a bowl guard, make sure the bowl lift is operating the bowl height switch. The bowl must be all the way up to operate the bowl height switch.
Jun 09, 2010 | Hobart H600 Stand Mixer
Bowl Lift Mixer does not lift!
well first you shoul read the menual to repair and then call the company and u can replace it.
Jul 23, 2009 | KitchenAid KP26M1X Stand Mixer
A200T Slips in low and medium speed
Planetary gears worn from, #1 changing speeds while unit running, #2 over loading the bowl. batter & icing max 75% bowl capacity, Dough max 65% bowl capacity
Jul 17, 2009 | Hobart A200 Stand Mixer
D300 Floor Mixer faulty bowl guard switch
If you remove the bowl guard you will see a magnet that attaches on iy in a white housing.The scews come loose and prevent it from closing the switch.Also the switch which comes out of the top pedestal can be adjusted.Let me know.
Mar 29, 2009 | Hobart D300 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
Hobart A200T General Info / Back cover plate gasket
I'm a service tech for hobart,I'll type your serial number into our database and see what it brings up.The changes that have been made---older units use a mechanical start switch on the motor,the new units use an electronic start switch.the old units center shaft and gears have changed.the older units dont have bowl guards and the new units do.(this is a cage that goes around the bowl).The gasket that your talking about is just that--a thin paper.The paper wears and you get that symptom you describe and its normal.I'll get back to you.
Feb 20, 2008 | Hobart A200 Stand Mixer
Sunbeam 2436 not working properly
did you mean model 2346? If you did, I am having same problem
Dec 17, 2007 | Sunbeam Heritage 2346 Stand Mixer
is there a bowl cage on the mixer?if not bypass the timer and see if it starts.
Oct 19, 2007 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
331 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
