Question about Philips 55PP9352 55" Projection Television
RESISTORS BABY BLUE BODY LINES BLUE,GRAY,GOLD,GOLD THE ONES IN PIC BLUE, ORANGE,BROWN, GOLD I THINK THEY TURNED DUE TO OUTAGE NOW WITH NEW IC ,S IN THEY WONT WORK TILL RESISTORS ARE REPLACE CORRECT THATS WHY EVERYTHING IS THE SAME? NOW ON METER I BOUGHT ONE SET IT TO WHAT TO READ ?
  • Philips Master
  • 8,617 Answers
The baby blue ones with the lines Blue,Gray, Gold ,and gold are the 6.8 ohm resistors the other resistors with the lines blue,orange,brown and gold are 630 ohm , Yes if those resistors are open even one of them the set will not converge. A digital ohm meter is more accurate, but you have to remove one side of the resistor to check them and if theyre open they wont read anything. If you leave them in circuit even a open resistor can measure good due to the resistance in the circuit. Removing 1 leg out of circuit then checking will spot an open resistor quickly.
Posted on Apr 04, 2008
After cleaning the lenses on my 60P8342a tv and turning the color buttons in the back my tv is shutting off and on and I have a flashing power button, no pic or sound at times
How long was it back befor you turned on this potentiometers ?
Dust and more can be come into the potentiometers of a crt (cathode ray tube) projetion tv in the years that its old it is not strange.
Ist an older kind of model of projection tv.
Treat them with contact spray , also not only red the r g b potentiometers but all the potentiometers that are parts of the convergention panel. and adjust them on a screen with the base saturation of color to zero so you adjust a good gray tray with a balans without a red brown or green or blue surplus so that you have white gray black in balance if you have adjusted , tur back on the basic color saturation to your prefered level.
Chances are pretty good that the weather will be fine.
To see some brown spots on the board and replace any carbon composite resistors for carbon or metal film resistors in the print because of high tolerance over this kind of resistance.
Feb 21, 2016 | Televison & Video
I have a 1997 Tahoe wont start but turns over
first check with your GM dealership ,they have recall on ignition key ,based on your vin# you may get lucky,
but if not here what you star with
there is a resistor in your key(people call it chip,but it is nothing but a resistor to complete the circuit) clean both side with alcohol wipe,also check make sure there are resistance from one side to other,if it is open you need new key
here are values,yours are one of these
Resistor Values:
  • 392: Orange, White, Red Black
  • 523: Green, Red, Orange, Black
  • 681: Blue, Gray, Brown, Black
  • 887: Gray, Gray, Violet Black
  • 1,130: Brown, Brown, Orange, Brown
  • 1,470: Brown, Yellow, Violet, Brown
  • 1,870: Brown, Gray, Violet, Brown
  • 2,370: Red, Orange, Violet, Brown
  • 3,010: Orange, Black, Brown, Brown
  • 3,740: Orange, Violet, Yellow, Brown
  • 4,750: Yellow, Violet, Green, Brown
  • 6,040: Blue, Black, Yellow, Brown
  • 7,500: Violet, Green, Black, Brown
  • 9,530: White, Green, Orange, Brown
  • 11,800: Brown, Brown, Gray, Red
next take the fuel pump relay out and check it
Check the fuel pump relay first, take it out and check the pins. If they are discolored at all, I would replace it. You can clean up those pins and try it, and make sure the female spring clips are tight too.
There is a hot wire straight to the pump but it's usually a real PITA to find. It's in the big harness leaving the under hood fuses, running under the brake booster.
next you check fuel pressure make sure,pump is working correctly
with key on/engine off should read 60 to 65 psi,with engine running about 55,next as engine running take the vacuum line off the fuel pressure regulator,and pressure should go up to 60 to 65,if not regulator is bad,also check inside the vacuum line and regulator if it is wet or gas present that means diaphragm in regulator is ruptured ,it is also bad,need to be changed,BUT BEFORE CHANGING PUMP.CHANGE THE FILTER ,SEE IF THAT BRING BACK THE PRESSURE UP, if all good then you need to check for spark
let me know and I can help you more
Apr 06, 2015 | 1997 Chevrolet Tahoe
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
Splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
For the Kenwood KDC-X589:
yellow - always on B+12 such as battery + terminal
red - switched B+12 such as ACC of IGN switch
black - body/chassis ground (- battery)
orange/white - dimmer control wire (car light control switch)
gold - to my knowldege no gold
brown - mute control from mobile phone
pink/blk - external amplifier control/trigger wire
blue/white - power control wire similar in function as the orange/white
blue/blk - to my knowldege no blue/blk
blue - motorized/power antenna
For the vehicle, pls postback info on year and make/model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 13, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Samsung HCN4226 Convergence.
Did you remove one side of the resistors from circuit to check them? If you leave them in circuit a blown resistor will test good as it will read the resistance from the surrounding resistors. Usually its the 3.9 ohm resistors identified bu the bands orange,white ,gold and red. and also the 150 ohm identified by the bands brown, green, brown and gold
Jun 23, 2008 | Televison & Video
Bad Resistor
Jonze,
Guess I should have looked to see that you had a second post. I justa answered one and here's some of the answers to my questions..
Brown - green - grey - gold would be a 1500m resistor and I would HIGHLY doubt they used something that intolerent in the convergence circuit... It's more likely to be a 1.5 ohm resistor which is brown - green - gold - gold and the grey you're looking at my just be discolored from heat stress...
Take a look at my previous post and tell me what you find after you make some comparisons.
Bill
Dec 09, 2007 | JVC AV-56WP74 56" Rear Projection...
Toshiba projection tv
there is no pink in resister codes
red or orange i think it's orange
32 X 8 or 5 32000 32K? most are low resistance
3.9 ohms and below.
Dec 06, 2007 | Toshiba 43HX70 43" Rear Projection...
Philips 55PP9352 55" Projection Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
