Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Canon Poershot sd300 digital elph. It just wont turn on period.
I dont know what happened to it. One day I go to turn it on and it just wont work. I charged the battery to a full charge, even bought a spare and it just wont turn on. I tried taking it out and the sd card, NOTHING WORKS! I tried rubbing the connectors with a eraser and the contacts on the battery and that didnt work. I am at a loss. PLEASE HELP!
  • Jon
    Jon Apr 04, 2008
    PLEASE HELP
  • 22 Answers
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Posted on Apr 10, 2008
  • Michael Kaskey Apr 10, 2008
    Oops, forgot the pic. Here it is:
Can you use an SDHC card in the canon powershot sd300 digital elph?
Although it looks exactly the same as a standard SD card, the format the SDHC card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera shuts off after E18 error code
You have most likely dropped the camera or banged it against something while the lens was out. This situation causes the brass pinion gear to shear teeth off the plastic ring gear on the Inner Lens Housing. It may also cause the guide pins to jump their track. If this is the case the repair bill usually exceeds the value of the camera and you are probably better off selling it for parts on eBay and getting a new higher resolution camera.
Dec 21, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
My canon sd300 will not turn on
I had the same problem, and finally I took it to a camera repair shop and they said it was time to get a new one.
Dec 17, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera will not turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jun 03, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Powershot SD300 wont appear on computer
nothing on a sd300 but there is on a Ixus 40, see below for IXUS drivers and manuals http://software.canon-europe.com/products/0010105.asp
Sep 12, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Use as mass storage device
Connecting a camera to computer via a USB to download is one thing- Connecting a camera to Computer to feed back the the card is another. The chances are the firmware on the camera will not accept anything that is not in EXIF format. Try it -simply connect camera in the normal way. This will if you have the normal A C D drives will come up us removable storage -'E' with the appropriate icon in 'My computer' Now pick a file[s] and using the normal Edit/ Select/ Copy[Or right click] routine then go to the removable media['E?' right click paste See what you get- you wont break anything
Aug 25, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon Power Shot SD300 Broken Screen
pretty easy to replace the screen, i suggest buy SD300 from ebay that has lens problem, but it is known for sure that screen is working, you might find one for $20-30, also look for SD200 you might find it cheaper and it uses the same screen as your SD300
Aug 19, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Memory Card is locked up?
Hi Phatback, There should be a switch on the card, move it in the opposite direction. If this does not work, format it in your PC. Please let me know if this works. Best regards, nightdiver
May 30, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
269 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
