Question about Sharp 55R-WP4H 55" Rear Projection Television
Convergence Adjustment Hi, I am also haveing trouble adjusting the convergence. When I enter the convergence screen you can tell the the color alignment isn't correct. I've tried to press every button, but i can't make any adjustments. Any help would be greatly appreciated. Thank you, Doug
  • Tidefan22 Jun 16, 2008
    What link can I go to to get the convergence ics and install instructions?
  • odindad Mar 18, 2009
    I can't get the red and blue + to line up eith the green on the bottom of the screen. The positions that will line up go back to the way they were when I exit.
    I have green shadows to the left of everything. It is worse on the bottom than the top.
    This just started two days ago.
  • Sharp Master
  • 8,617 Answers
You need new convergence ICs let me know if you want the link to where you can get new ICs along with free installation instructions and instant messaging tech support for free to do the repairs.Thats a free service for customers who buy the ICs
Posted on Apr 04, 2008
Fixing color convergence red and blue lines
most TVs have an adjustment for convergence in your on screen menu, go into convergence of service menu & try to adjust; it it is still too far out of convergence contact a service technician as convergence issues can be very difficult to resolve unless you are very sure of what you are doing.
Dec 26, 2014 | Televison & Video
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Sony kp-53xbr45 please let me know step by step how to enter in convergence service mode thank you
follow the below steps:
To Enter Service mode With the tv off and the remote in tv mode, press the following keys:[DISPLAY],[5],[VOL UP(+)],[POWER]
The tv will now display "3D-COMB" in the upper left hand corner.
Press the [2] or [5] keys to move up or down through the adjustment categories until you see "PJE" in the upper left hand corner(note that the letters will change to a different font).
Next press the [6] key twice, this will bring up a grid (crosshatch) without video behind it. When I refer to the [CENTER] key, It is located in the middle of the directional arrow keys on the remote.
When cursor is white, you can move it to an adjustment point using the arrow keys. Once you press the [CENTER] button, the cursor will lock to that adjustment point. It will now change to one of three colors ; Red, Green, or Blue. The color of the cursor will be the color you are adjusting. To change the color press the [3] key only when the cursor is locked to an adjustment point, pressing the [3] key when you are in navigation mode will have no effect. By Pressing the [CENTER] button again will switch you back to navigation mode.
To save your changes press the [MUTING] then [ENTER] keys on the remote.
Also, your tv may or may not have different convergence modes that you will have to adjust, if your tv is a hi-def you will need to converge the hi-def mode as well, With the cross hatch up you can press the [DISPLAY MODE] key to switch between the different modes. Make sure you save your changes before changing picture mode or your changes will be lost.
style="font: 7pt 'Times New Roman'"> On tv's that have different screen modes, you can try to copy the settings from the full mode once you have saved the setting by pressing [MUTING] then [ENTER] . To do this select the "ALCP" mode then change the data to "01" then press [MUTING] then [ENTER] again. the data from the full mode is then copied to all other modes. This procedure works for the "RA6" chassis, this procedure may be different in different models
Additional Information:
  1. Save changes often.
  2. The green crt is used to align the other two colors. If you need to get the grid straight, straighten up the green completely before adjusting the other colors. An overlay may be needed if the green is way off.
  3. After adjusting a point, you may throw another point out of convergence, Check for this.
  4. Start converging in the center and go out, don't start on the outside you will be fighting the convergence if you do.
  5. Avoid the tendency to adjust the worst point first, most likely one of the other smaller adjustments will get that badly converged point very close to where it needs to be. By adjusting that badly converged point first, you can throw off a well converged point somewhere else.
  6. If you are at the edge of the screen adjusting a point there, look at the opposite edge of the screen, you can throw a point off on the other side if you over adjust.
Good luck.
Jul 07, 2010 | Televison & Video
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Apr 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
Convergence problem
This is out of the service manual
don't forget to write the setting to rom by hitting the pip button twice
Good luck and don't hesitate to ask questions
2.12.5 Convergence point adjustment
Adjustment preparation
(1) Select color to adjust.
“STATUS” - Green
“0” - Red
“ANT” - Blue
(2) Use 4, 6, 2, and 5 to move the cursor position
(dotted lines).
(3) Use thumb stick to move the convergence point.
(4) Three adjustment modes are available:
1. (3x3) Press “STATUS” 5 times (only works
when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
For touch-up, only the (13x9) mode is necessary.
This will adjust every cross-hatch intersection point
on the screen.
For complete adjustment, start with (3x3) mode. This
will adjust center point and eight edge points only,
but will greatly reduce adjustment time. Then use
(7x5) mode, and finally (13x9) mode to finish
If “S” distortion appears between cross-hatch lines
repeat (7x5) mode to change calculation process
while adjusting to remove distortion, then return to
(13x9) mode to finish touch-up convergence.
Adjustment procedure
(1) Receive any NTSC signal.
(2) Start adjustment at the center of the screen.
(3) Continue adjustment at next closest position.
(4) Adjust center area first, ending with edge sections.
(5) Press INFO button to perform calculation operation.
This process will take about 2 seconds and no
picture will be seen at this time.
(6) After interpolation, check convergence again and
repeat (1)-(5) if necessary.
(7) When convergence is acceptable, press PIP MODE
to write data to ROM memory. ROM WRITE? is
displayed to alarm system that ROM will be
overwritten with new data. Press the PIP MODE
button again to write displayed data to ROM.
(8) DATA WRITE TO ROM will take approximately 4
seconds and no picture will be displayed.
(9) Green dots will be displayed when operation is
(10) Press MUTE to return to convergence pattern, then
confirm again convergence is acceptable.
(11) Press PIP MODE (ROM WRITE) mode, then press
PIP CH to initialize sensor data positions.
(12) Input any 1080I signal.
(13)Press EXIT key 5 times to exit video mode.
(14) Select an input with 1080i signal.
(15)Access menu and select ASPECT 5 mode.
(16)Press the SERVICE SW. ONLY button to enter to
DCU crosshatch signal.
(17)Repeat steps 2~11 above.
Notes: (1) Display only green for easier adjustment and
match to jig screen. Press “MENU”, THEN
(2) Perform interpolation and data write to ROM
after green adjustment. Once green has been
confirmed to match jig screen, the jig screen can
be removed. Do not readjust the green color
after jig screen has been removed. This is now
your reference color.
(3) Display green and red only and match red to
(4) Display all colors and match blue to green and
red. Touch-up red color if necessary.
(5) Existing DATA in ROM can be read by pressing
the SWAP button 2 times. This data can be used
after replacing a component (CRT, DY, etc.)
Where complete convergence adjustment is not
necessary, be careful not to overwrite this data.
DO NOT write cleared RAM data into ROM or a
complete convergence adjustment will be
necessary. Remember to try MAGIC FOCUS
before starting convergence adjustment to
minimize adjustment time.
Feb 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Convergence adjustment for red and blue
Press the MENU/SELECT button
on the remote control to show the
on-screen menu.
to enter the PICTURE menu.
repeatedly until CONVERGENCE
is selected.
to enter the CONVERGENCE
adjust the cross image until the color
outline around it is gone.
Press the STATUS/EXIT button
to exit the menu from the screen.
Aug 21, 2008 | Philips 60P8341 60" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence adjustment @ 52MH84
press mute on the remote then while pressing mute press menu on the set.then you navigate with the instructions below.
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Jan 21, 2008 | Televison & Video
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Sharp 55R-WP4H 55" Rear Projection Television Logo
271 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
