Sceptre X22wg Gamer flicking and resize
2 month ago i bought one Sceptre X22wg Gamer, since the last week, the monitor is flicking a lot while it s conected to the DVI input, and when iswitch the conection to VGA input, a green background appear in the screen, turning the image with a marked green tone which make the working labor very difficult.
some time i can work a couple of our through the DVI port, but
sundenly it start to flick and resize the image.
can you explain me what happen with this monitor?
  • jcjanko Apr 19, 2008
    You mean the the video interface of the monitor it self?, or you reffer the computer video card?
    How can I get this Board
  • Anonymous May 16, 2008
    I have a 22" Sceptre monitor that flickers after about 10-15 min SOMETIMES it it goes correct. Then the next time it won't come on at all. It does this over and over. Do I need a interface board, are they interchangable (brand wise) , expensive and are there intructions to do it yourself> Thank you Karyn
Yes , the video interface of the monitor.
try surfing :
www.lcdrepair.us
Have a try ,may be you can order video/logic board via them.
Posted on Apr 19, 2008
  • 180 Answers
Your video board is defected.
My sceptre x22wg monitor has recently been turning off when turned on, how can i fix this? i use this for a dual monitor setup so this is very frustrating to me
Make sure windows finds your monitor in your OS(operating system) Start<My Computer< right click on my computer and click properties< device manager < goto Monitors and see if windows finds it. If you have a graphics card, make sure the card has the latest driver installed from the webite.
www.nvidia.com www.ati.com
Jun 05, 2011 | Sceptre x22wg Gamer Monitor
My sceptre X22WG is no longer showing white screen but getting progressively darker blue. How can I get it back to a white screen?
Colour changes like this are either due to a failing graphics card, failing monitor or bad connection from the computer to the monitor.. with this monitor, I'd have it checked by a tv repairman
Jan 18, 2011 | Sceptre x22wg Gamer Monitor
X22wg-Gamer Monitor: It appears the power supply is dead, what can I re...
you need to check if your capacitors are blown, if they are, you can replace them...it's a very economical way of fixing it. This is a common problem of Sceptre x22wg-gamer.
May 16, 2010 | Sceptre x22wg Gamer Monitor
Monitor will not turn on blue light flashing bottom right hand of monitor
I'm having the same problem. Had the monitor for almost 2 years and everything was working fine until this week. The blue light would blink, then after an unpredictable period of time, the monitor would turn on. Seems like it needs to warm up or something. I suspect it has something to do with the capacitors not charging inside. Somewhat disappointed with Sceptre. I suppose I should be thankful that I got 2 years out of it.
Oct 09, 2009 | Sceptre x22wg Gamer Monitor
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
X22WG-gamer sceptre 22" monitor won't power on. It's not the power cord because I've used the power cord on a different monitor and it worked fine. Any and all assistance will be much appreciated.
Your monitor has 3 or 4 blown caps right next to the power plug. They are CapXon 470uf25v. Just open the back and remove the power board, desolder, and replace the 3 or 4 caps put it back together and it should go back to working. This a typical problem with the Sceptre gamer, HP1706, and the HP1903. And guess what they all have the same caps blown in almost the same place.NOTE: When seperating the case the power led is glued to the front frame. Take your time if you rush you will break a cable wire or plug.
Sep 07, 2009 | Sceptre x22wg Gamer Monitor
My Sceptre x22wg-Gamer Monitor isn't getting any power, HELP!!!
I have two of the X22WG monitors, both dead. The power supply in this model is apperently plauged with a common error. The problem is close to the +5V and +12V output connector (Far right corner, with power plug against you). Two out of the four small caps are blown. Replace those, and it should be fine. C551 and C552.
Jun 09, 2009 | Sceptre x22wg Gamer Monitor
I have a Sceptre x22 gamer that has been serving me well for about two years. A week ago I started having trouble getting the monitor to ''Wake Up'' after the computer goes to sleep or when rebooting. It...
warcryofjuda, One of the guys that I work with brought in a small screen Sceptre DTV/DVI/VGA +audio unit. and it also has a optional TV/tuner module. mod S1701DTV with side mounted speakers. The viewable screen size is 14"w x 8.75"h . Oh! First things first! Turn it OFF and leave it off. Disconnect it and put it in a safe place for now. IT'S BROKE!! It will not work today, and it will not work tomorrow or the next day. Got that? Ok! Now I want to know if you would like to work together with me and explore both of these monitors and possibly come up with a fix for them? Please get back to me via my email with what ever approach you feel is best for you. We have already opened up our unit and I will try to attach some pic's for you to compare your unit with. I'm louie12fix on fixya or lmistyrel@aol.com
Bye for now.
Apr 15, 2009 | Sceptre x22wg Gamer Monitor
Screen is covered with horizonal multicolored lines.
1st and least expensive is to replace the video connection cable. Try that
Cheers!
Mar 26, 2009 | Sceptre x22wg Gamer Monitor
Computers & Internet Logo
531 people viewed this question
David Payne
David Payne
