I have placed mp3 files on a usb stick, to play in car, pluged into a cigarette lighter socket fm transmitter. the problem is it plays but has a lot of static or vibration to it. i have checked the quality of transfer of mp3 file, made it the highest quality, i have also checked the rock, pop equalizer.i have turned that to normal. it still does it.
    Genius:
  • 1,027 Answers
Check to make sure the fm transmitter is digitally locked on the correct station on the radio and that the end that fits into the cigarette lighter is tight. The end twists on, so make sure it is tight.
the fuse is under that cap.
My transmitter has 7 channels to choose from. beginning with 87.7,87.9,88.1,88.3,88.5,88.7,88.9
Posted on Apr 04, 2008
SOURCE:
I cannot play music through fm modulator by usb but it works i phone/
Select free channel or frequency on your radio and align it with the one on fm modulator depending on the type of radio used. Make sure the modulator has the power on. Does the cigarette lighter work, if not check it. make sure the radio receiver/ transmitter component or antenna connected as this need frequency to produce sound like a radio.
Feb 24, 2015 | 2003 Toyota Corolla
Tip
How to add an iPod Input into a Stock Radio?
<p>You can add an iPod to a stock radio in your car, even if the plant does not have an auxiliary input or iPod input using a specific number of iPod car accessories. One such accessory is a cassette adapter that plugs into your iPod as a headset, but ends on a cassette tape to your stock cassette radio. However, not all cars have cassette players, thus more accessible to the FM transmitter. <br /> <p><br /> <p>1. Connect your iPod to an FM transmitter, if you connect headphones to the iPod. <br /> <p><br /> <p>2. Connect the FM transmitter to your cigarette lighter to power and then to the transmitter. <br /> <p><br /> <p>3. Press up and down on the transmitter to the FM transmitter to change, you will pass the signal to your radio. Choose a station that is not a radio station on it so you do not interrupt the signal. <br /> <p><br /> <p>4. Set your stock radio to the channel you selected on your transmitter and then play the songs on your iPod. You will see the songs on your iPod through the radio station you selected. <br />
on Aug 09, 2011 | Apple iPod touch
Bought 4gb sandisk cruzer flash drive stored music from computer but it won't play the music on the car fm transmitter
a flash drive is used mainly for storing of files, you need a device that will play the files you want, in this case a device that plays mp3s and either transfer your music to/through it.
Unless your transmitter states that it plays different media formats that is but i have never heard of that before.
hope this helps.
Dec 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Can you keep player plugged into usb charger while playing music files indefinatly or will it over charge and possibly cause damage? im shopping around and am not even shure it will play while pluged in to...
You can keep the Sansa plugged in without fear of overcharging. The Sansa will play while it is connected to a USB port that is supplying only power, such as a USB charger operating off a car cigarette lighter. It will not play while connected to a computer.
Mar 09, 2011 | SanDisk Sansa Clip MP3 Player
Will the sansa clip play through my car sterio fm station?
The Sansa itself won't, lacking an FM transmitter. You can buy such devices at just about any department store, however. Most of them draw power through the car's cigarette lighter, and some can even power/charge the Sansa. Make sure you get one that isn't exclusively designed for an iPod, as the power connector on the Sansa is not compatible with that on the iPod. The headphone jack is, of course, universal, and that's where the sound comes out.
Apr 20, 2010 | SanDisk Sansa Clip MP3 Player
I have a number of RiDiscs with 4.7GB of material ( lectures) that I want to download on smaller discs so that I can play on my car cd player. How do I accomplish this?
The easiest way:
check the item on the link below:
http://www.i-source-global.com/epages/170990.sf/?ObjectPath=/Shops/170990/Products/RFMP3SD2&ViewAction=ViewProductViaPortal&Locale=en_US
Copy your audio file from the disc to a USB (pen drive) I am assuming your files are in mp3 format. Else use the audio ripping software mentioned below to rip the audio file and save in mp3 format and copy that file into the pen drive/SD card.
Connect the transmitter to your cigarette lighter adapter. Turn your car radio on. Tune the FM channel to a frequency, where there is no radio channels. Note that frequency. There will be a + and minus button on the transmitter. Press it up or down to bring the transmitter to the noted frequency. You can now hear the audio through your radio.
Different options of this transmitter are available. Some use a SD card instead of USB drive. All cost around $25.00
The second method is to rip the audio files to your hard disc. Use any software. For an example,
Check the link below:
http://www.freerip.com/
Download and Install. If your cd player is capable of playing MP3 files, rip the audio files from your disc as mp3 files to your hard disk. copy them to regular cd's. (assuming you have a CD burning software)
If your cd player is not capable of playing mp3 files, rip them and save as .wav files.
Then you need a cd burning software.
Go to the link below:
http://alternativeto.net/desktop/k3b/?platform=windows
Download K3B. Install
Open it. Select, a new audio project.
Drag your .wav files into it. Burn it. and you are ready to go.
Feb 25, 2010 | Compaq Presario 5000 PC Desktop
Any way to play songs from iPOD or MP3 player in a 1999 ES 300??
you can buy an FM modulator and plug your i pod into that..........the modulator plugs into your cigarette lighter socket for power and will then transmit the i pod signal to a station on your FM radio...........you should be able to find one at any electronics store
Dec 24, 2008 | 1999 Lexus ES 300
Does Gogear charge via the USB plug or only via the 13 amp plug
You should be able to use the play side but I do not think you will be able to charge it.
The transmitter side is taken from the earphone socket.
The power comes from the mains plug via. the Philips lead and is at 5 volts.
I could be telling you wrong as I do not know what adaptor you are looking to purchase.
Dec 06, 2008 | Philips GoGear HDD6330 MP3 Player
Just bought a new Philips MP3 Player Model SA3025/37 and was wondering if I can use it in my car?
You can use any MP3 player in your car by connecting to an FM transmitter.
Look for FM transmitters on E-Bay.
They are powered by either battery, or cigarette lighter adaptor.
They plug into the headphone socket of the MP3 and convert the output into an FM signal, which you can tune your car radio into.
Jun 07, 2008 | Philips Audio Players & Recorders
 Grubhead
Grubhead
Marvin
Marvin
