Increasing Resolution I am unable to increase my resolution from the minimum. When I try the monitor says out of range
  • 57pan Apr 04, 2008
    Im sorry I tried to to put the model down but the screen would not allow it. The monitor is a Tatung L79 SVGA color display. My operating system is Windows XP
    Novelist:
  • 119 Answers
Dear 57pan
Sounds like you have not installed the driver correctly or the driver is corrupt. Please find the driver again for your graphics card/and the monitor's and reinstall.
Unfortunately you dont state the model/maker/windows operating system and cannot help any further with instructions/manuals/driver files.
I hope you can fix this,
Regards
Please dont forget to rate this solution if you found it usefull.
Posted on Apr 04, 2008
Why is my screen display is very fuzzy
If this is a CRT monitor (glass tube) then there should be a focus control to adjust on the back of the monitor.
If it is an LCD (flat screen) then you may have the resolution set too low. Go into 'Display' in 'control panel' and try increasing the resolution.
May 30, 2014 | Computers & Internet
Monitor's resolution need to be increased, how?
Hi
You don't say which operating system you are using.
The monitor resolves images across a fixed range of resolutions and resfresh rates.
It is the resolution of the graphics card or graphics adapter that can be changed, not that of the monitor.
Right click on empty space on your desktop > properties > settings.
Left click and hold on the slider and slide to the right in stages.
Each resolution change offers you a test page to accept or reject.
When satisfied Apply > Yes > Ok.
To reset the Refresh Rate:
Properties > settings > Advanced > Refresh Rate.
Then restart your computer.
Be careful not to exceed the resolution/refresh rate range of your monitor (1280 x 1024) / 75.0 Hz because if you do, when you restart the computer, the monitor will be unable to resolve the image and you will get a blank screen and/or an Out Of Range error message.
An out of range problem might only be resolved by using a different monitor to reset the resolution back to within the range of the preferred monitor.
Hope this helps
Aug 22, 2011 | Northgate MONNG7NSS 17" Flat Panel LCD...
I continully receive a message of the screen is not in optimal mode of 1920X1080. I have gone to the screen setttings and have applied this yet I continue to receive the message when I go to play a game....
Your game does not natively run at the same resolution as Windows. Check the video/graphics settings in the game itself to adjust the resolution to 1920x1080.
Note that increasing the resolution to this, will drastically increase the load on your graphic card.
Feb 26, 2011 | Samsung SyncMaster 2233SW Monitor
We switched it to a different computer and the picture flickers
hi this could be due to the fact that the resolution is set incorectly on the other computer, try lowering it to the minimum at first then increase the resolution and see what happens...hope this helped
Mar 14, 2010 | Westinghouse LCM-19v1 Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
2 problems: 1. Is there a way to make the images on my 19 inch acer lcd monitor not appear stretched? 2. How do I get a screen resolution of 1440 x 900 (It's not one of the options in my display...
1. The only way to avoid stretching of images is by increasing the resolution. Many 19-inch monitors with conventional (4:3) aspect ratios have 1600 x 1200 pixel resolution. The 1600 x 1200 resolution is ideal for graphic artists and those who work with photos, since it's close to the resolution of a 2-megapixel digital photo.
2. You can double check by going to the display properties - Settings- Advanced tab below the screen resolution slider, choosing the Adapter tab, click List all modes and that will settle it once and for all. If 1440 x 990 isn't listed you're likely going to have to buy a graphics card that can reproduce that resolution.
Also try and update the driver for your graphics card.
Jul 06, 2008 | Acer Computers & Internet
Problem with my LG monitor L194WT
First change the referesh rate for your monitor. If that works, then you dont have to change the resolution. If that does not work, try increasing the rate again. Once you can get the game, then try to change the resolution from within the game options, if necessary..
May 27, 2008 | Computers & Internet
You will have to increase the referesh rate first and then go into the game and reset the resolution. The resolution bit is secondary. If increasing the refresh rate works, then you dont have to change the resolution :)
Monitor resolution conflict
Install the Drivers for your New Monitor and then try increasing your resolution. If fails to solve, contact your Monitor Vendor (Seller).
Sahaja Yoga is FREE OF CHARGE and is the MAHAA YOGA.
Apr 23, 2008 | Acer AL1916W 19" LCD Monitor
LG Studioworks 900B 19" CRT
Try using the minimum supported refresh rate. Also set the resolution to the minimum that will please you (for example 1024x768). See whether the lag still occurs. (Use the nVidia control panel to change the settings). If there is no lag, you can increase the resolution step by step (if you feel the resolution is too low) and keep on increasing until lag occurs. Set the res just below that value.
Nov 28, 2007 | LG Studioworks 900B 19" CRT Monitor
Computers & Internet Logo
530 people viewed this question
David Payne
David Payne
