I need the code for a tv that i just received so I can program the code into my remote so I can use it
    Master:
  • 518 Answers
Most remotes of that type have a "Code Search" feature, and it's the easiest way to find the code. You would put the remote in search mode (follwoing the manual instructions) and run through the codes 1 at a time, if you see the Unit turn off, you store the code.
Hope that fixed ya...
Geno
Posted on Apr 04, 2008
SOURCE:
Codes for a conect rm500 remote
I have a RCA MODEL TV 27V514T and a conect-it RM500 UNIVERSAL REMOTE CONTROL I just need the code to program my TV. Please help me.
Feb 26, 2013 | Conect It RM500 Multi-Brand Universal...
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
What are the codes for a 153639?
wtlc50
I have provided a link for instructions on how to program your remote. You weren't clear if you were having problems with the remote working on your receiver or your TV. Step 5 is for programming the remote to your receiver, with step 6 programming the remote to your TV. I have also provided a link with the codes for the different TV manufacturers.
Readdress remote to receiver (step 5) / program to TV (step 6):
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Aug 27, 2010 | DISH Network IR Remote Control
Power button and volume buttons not working
bronco71430
I have provided a link with instructions on how to program your remote to your TV. You will select your receiver from the list of instructions for the receivers. You will also need to select the link with the TV codes. You only need to follow the directions to get your remote to work on your TV. If this doesn't work, you may need a new remote. I hope this helps.
Program the remote to TV and TV codes:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Sep 30, 2009 | DISH Network IR Remote Control
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Dec 27, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Ekse
