Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
55 philips replaced ic's as suggested and still red /blue around everything...
ok heres some pics with the crosses cant move adjust or anything ... replaced ic with exact ones you suggested ... what do you think ? its killing me ....
  • 2 more comments
  • blue muscle Apr 04, 2008
    sorry i put the wrong one in my last reply its 55pp935217
    NO DIDNT LIFT OUT I FEEL DUMB .. I PUT AN OHM METER ON THEM AND ALL AROUND AND JUST SEEN WHAT THEY READ ... FROM THE PIC WE KNOW 2 ARE OUT .. BUT DONT REALLY KNOW HOW TO USE OHM METER ...
    THE ONE I GOT IS DIGITAL OK SO YOU THINK THE 2 IN THE PICK MIGHT BE DIFFERENT AND NOT JUST BURNT ... I WILL CHECK THEM LIKE YOU MENTIONED THEY LOOK A LITTLE BROWN AROUND THE EDGES
    DO YOU THINK I DID ANY HARM TO THE NEW IC'S BY TRYING THE SET WITHOUT REPLACING ?
    3157, 3158, 3159, 3160 ARE ALL OPEN .. WHEN I PUT METER ON THEM MY HAS A BEEP SETTING THERE THE ONLY ONES FROM 31-- TO 3160 THE NUMBERS YOU MENTIONED THAT DONT BEEP OR THE NUMBERS MOVE ...
    RAN TV FOR ABOUT 15-30 MINUTES ....
    OK THESE RESITORS LOOK LIKE BEIGE BODY , BRONZE OR GOLD , BROWN OR BLACK, ORANGE, DARK GRAY OR BLACK...
    ANY CLUE TO WHAT THEY ARE AND CAN GET THEM AT SAME PLACE ?
  • Philips Master
  • 8,617 Answers
Now the heading list your model as 55PW9363 Which model number is your set? If the resistors arent open it has to be a pico fuse, But I wasnt aware that the DPTV series have pico fuses, they do have fusible links solderd directly to the circuits. Let me know your accurate model number. I was under the impression it was the 55PP9352/17 which is the DPTV305 series chassis or Mag01 which is the same except for magnavox
Posted on Apr 04, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Apr 04, 2008
    did you check the resistors i indicated in the post before my last by lifting 1 leg out of circuit to see if they are open, because if they arent within 5% tolerance you wont have any control over the convergence. And that model usually will open at least two of the 6.8 ohm resistors when the ICs go out.
  • Sonny Berry
    After you lift one leg out of circuit just set the ohms meter to RX10 or RX100 for ohms ifs it isnt digital and if the resistor has continuity(needle moves) its probably good. if the needle doesnt move its open and will need to be replaced.
  • Sonny Berry
    usually the ics will hold up for a little bit. If you find an open resistor replace the open ones, and your ICs should still be good if you didnt run it for very long . Those ICs are pretty strong when they are new.
  • Sonny Berry
    the resistors that are open should be 6.8 ohm like all the rest in the series of numbers that i listed in the other post to you. I cant tell by the banding unless you cab be absolutely certain of their colors. but according to the service manual those resistors that I listed last night should all be 6.8 ohm all the way to and including3160. did you buy this set new? Is there a possibility that someone before you put the wrong ohm resistors in, as they should be 6.8 ohm also.
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
A lot of red in pic no matter what we do and tint dose not change anything
As is typical with all Philips projection sets the cooling fluid has become contaminated in the blue and green picture tube assemblies. The red is almost never affected with this as whatever bacterial growth is discoloring the fluid in the blue and green tubes can't seem to survive in red light. The blue and green light is shining up through muddly cooling fluid and that is why the red is predominating. A reputable tv repair shop can pull the tube assemblies and dismantle them and clean and reassemble and refill and do all the necessary adjustments for around $300 to $400.
May 26, 2009 | Philips Televison & Video
Sony kp-61v45 Blue Convergence off by 2 inches
you need to replace the convergence board its around 80 dollars
Aug 17, 2008 | Sony KP-61V45 61" Rear Projection...
RED SHADOW AROUND IMAGES of SONY KP-57WS510 RPCRT
Your set uses two STK392-560 convergence ICs they are attached to a large heat sink on the D board. You can save your self about 400 for a twenty minute repair by getting new ICs at the following link as trhey provide free instalation instructions with pics so you can do the job yourself. It only requires basic soldering skills I would order about six 4.7ohm 1/2 watt resistors as well just in case you need them asusually sonys' will burn one or two of the 4.7ohm convergence resistors when the ICs fail. Heres the link
http://servicemanuals.vstore.ca/
May 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Mar 28, 2008 | Philips 55PP9352 55" Projection Television
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Magnavox Projection Convergence
You may have had another problem if the screen was wavey. This is typicaly caused by the opto chip. Check www.magnavoxhelp.com for more details.
Jan 12, 2008 | Philips 9P5034C 50" Rear Projection...
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
Convergence
Typical convergence IC falure. Need to replace both at once as if ones down now, a few months down the road another one will be down. This is not a consumer or end user replacable part. As its all soldered into place and your going to need to do a master convergence alighnment when they bare replaced.
Sep 02, 2006 | Philips 60P8342 60" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
164 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
