Question about Creative Labs ZEN V Plus MP3 Player
Firmware problem i had my zin v plus on the charger and when i decided to take it off, it dsplayed a recovery mode display and everytime i reset of turn it on, it say that it has a firmware problem
  • 9 more comments
  • surfbanger Apr 05, 2008
    yeah i have the same problem with my creative it says firmware problem what should i do :(??
  • moe96 Apr 05, 2008
    say it has a firmware problem when i cut it on and off it want play my music. What do i do? i read instructions but it didn't work HELP!!!!!!!!
  • drumbum7856 Apr 05, 2008
    My Zen V plus says that i need to reload my firmware but i dont know how to..how do you reload firmware? i have my usb cord and my starting cd if that helps....
  • Anonymous Apr 16, 2008
    my zen says firmware problem
  • Anonymous Apr 23, 2008
    i had my zin v plus on the charger and when i decided to take it off, it displayed a recovery mode display and every time i reset of turn it on, it say that it has a firmware problem
  • tevin2625 Jun 06, 2008
    i have the same exact problem
  • Anonymous Dec 31, 2008
    my zen got froen after i dowloaded tge music on it
  • Anonymous Feb 26, 2009
    mine has the same problem and i cnt even use it or anything
  • Millie_0734 Mar 03, 2009
    my zen plus keeps telling me "firmware problem" what can i do?
Ok well firmware i figured out is kind of like the format..i dont know if there is another way to do it but this worked for me...go to the creative homepage..idk what it is..google it..anyways look on the dowloads..make sure ur zen is listed..should be..than click download..dial up..which i have..might take an hour or so..it wokrs..itll take off all ur music though which stinks but its worth it i think...hope this helps..please rate it if it workss..
Posted on Apr 20, 2008
  1. tengo un problema en mi mp4 k me sale alli cuando lo enciendo fimware problem
Posted on Jan 05, 2010
Go into the following webpage and download the mp3 recovery tool..............creatives aint ripoffs
Posted on Apr 18, 2008
I have a creative zen m vision which is not working if I try to reload firmware I get a message harddidk problem - how do I proceed
1 HD damage could be done when you drop the Zen and you hear noises inside, some times the display just shows the Creative logo and no more.
2 the display just show the Creative logo, no noises inside, you can tray to put in Recovery mode as mentioned in the other solution and then erase firmware then reload firmware, this firmware can be downloaded form creative page,http://us.creative.com/support/downloads/download.asp?MainCategory=213&nRegionFK=&nCountryFK=&nLanguageFK=&sOSName=Windows+XP&region=1&P
However
Before you go to all that trouble though try these steps:
1. Connect the device to the wall charger.
2. Hold the power switch to ON.
3. Put a paper clip into the reset hole.
4. Continue holding the power switch on until the Creative logo appears.
5. Select Format All from the Recovery Mode menu. (Note: THIS WILL ERASE ALL DATA FROM YOUR DEVICE! - but it's better than buying a new device)
6. When the reformatting is done, select Reboot from the Recovery Mode menu.
Jan 08, 2011 | Creative Labs ZEN Vision:M Digital Media...
Philips mp3 player
If you have tried the reset, then it could be one of the following:
1. faulty charger - Need to replace it
2. Faulty/failing battery - Need to replace it
3. Faulty contacts / cable - Need to replace the cable or service the unit for faulty contacts.
If you are able to switch on the unit, try the following:
Please follow the steps below to recover and upgrade your player with the latest firmware:
  1. Make sure that your computer is online and connecting to the Internet.
  2. Launch the Firmware Manager at Start->Programs->Philips Firmware Manager on your PC.
  3. Connect your GoGear to the computer while pressing & holding the 070119082257_17362.gif(>||) key until the Firmware Manager recognize the GoGear and a dialogue boxpop up in recover mode.** If you failed going to recovery mode, “pleaseconnect the device in recovery mode” is displayed please repeat step 1to step 3.
  4. Click Start to confirm and start recovering the unit to its factory setting.
    IMPORTANT: All music & content of your GoGear Player will be erased once the factory setting is restored.
  5. Follow all screen instructions and click Finish at the end to complete the recovery.
  6. The Firmware manager will close automatically once the success message is displayed.
  7. You can now remove your player and start using it again.
You could also try to manually upgrade the firmware and see if that helps...
Oct 12, 2008 | Audio Players & Recorders
Stuck in recovery mode, firmware problem
i have the same problem of recovery mode. can you help me please
Jul 12, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Recovery Mode
Clean Up
Format (All)
Reload OS/ Firmware
Dec 28, 2007 | Creative Labs ZEN V Plus MP3 Player
Help
Clean Up
Format (All)
Reload OS/ Firmware
Recovery Screen, take 2.
If your Zen is not responding or in a "reboot loop" the following information from creative explains how to access the players recovery mode
Hope this helps, and good luck.
Zen V Plus and Zen V
1.
Clean Up
Format (All)
Reload OS/ Firmware
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Dec 27, 2007 | Creative Labs ZEN V Plus MP3 Player
STUCK in RECOVERY MODE
Clean Up
Format (All)
Reload OS/ Firmware
Dec 17, 2007 | Creative Labs ZEN V Plus MP3 Player
Language in zen
To reset the language displayed on a ZEN player to English, change the language back to English or run Cleanup from the player.
For detailed instructions on how to access the Recovery Mode of a MP3 player, please see Recovery Mode: What to Do and How to Access.
If the player is a flash based player, such as a ZEN Nano, ZEN Nano Plus or MuVo, the language can be reset by manually changing the language or updating the firmware. To manually change the language:
  1. Press the scroll wheel to access the main menu.
  2. Scroll to the Settings option (the icon looks like a gear).
  3. Scroll to the Language option (the icon looks like a pearson speaking).
For detailed instructions on how to update the firmware of a MP3 player, please see Updating the Firmware on a Creative MP3 Player.
Dec 05, 2007 | Creative Labs ZEN V Plus MP3 Player
Recovery Mode
The same problem happened to my sister when she reformatted. All you have to do is go on the internet fine the latest firwire software and download it on to your Zen V Plus.
Sep 05, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
460 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
