Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Coffe machine has been repaired 3 times due to steam leaking into the LCD panel. Unit is 15mths old and is used dailt for gousehold use.
  • 515 Answers
Have the steam valve been replaced?
If they replaced it by a metal valve then i think the machine is leaking from the tube.
Posted on Jul 10, 2008
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Red exclamation point light flashing
For Saeco Odea Go Team De-Brewerz.com says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler.
3. Remove the brew unit from the machine. Check the mechanism and refit the same into the machine.
You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @www.De-Brewerz.com
Nov 03, 2014 | Saeco Odea Go
My Francis Z1 machine has lost pressure. The coffe is not as good as it was, it´s more of water than foam on , i´m using pods. The steam is not working anymore. It leaks water and sometimes the...
Your machine have different small problems.
First the steam is not working since during descaling one small scale part blocked in one poind the pipe or valve so the water can not pass and create steam out.
The second problem you describe is that the thermostat which is located on the thermoblock-boiler is not working properly so it does not switch off heating thas you have overheating and thus the valve explosion when the pressure go very high. Also if you try to make a coffee with this very high pressure so very hight temperature then the coffe will burn so you will have atery coffee without cream.
So your machine need to desasembel and manual descale pipes and valves and also to replace the thermostat.
It worh it if you can do it your self or if you find a service that will not charge a lot since you mostly need labour and not parts.
Good luck and thank you for voding
Aug 10, 2010 | FrancisFrancis! X1 - Stainless Steel...
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Leaking steam valve rancilio miss audrey
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
Apr 01, 2009 | Rancilio Audrey
Leaking
You need to contact Delonghi and order a part. This is the steam/water outlet assembly. This part includes an electronic solenoid which controls the water and steam output. I have had this problem 3 times. You may find the steam/ water is very loose when you try to wobble it sideways. This is the indication as to what is the problem, (as mentioned above).
Jan 27, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Machine is leaking
the valve is available at partsguru.com in the US
Apr 16, 2008 | Gaggia Syncrony Compact Coffee...
Buzzing Espresso Machine
that noice is from your solenoid valve during brewing coffe.
  1. as first you should clean the group with blind filter and special detergent for washing coffe from group. if you didnt do this long time you should repeat the cleaning 3 - 5 times same day.
  2. if you follow the 1st instruction but you have the problem again you should change your solenoid valve.
Mar 18, 2008 | La Marzocco Linea Series Group 3 Espresso...
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
85 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
