Help!!!!!!! my acer 5701. windows event log is telling me my system is critical and i have alot of errors, ive downloaded a tool maintance to repair it all but i still have performance issues and start up issues etc... my laptop is running so slow. and im getting blue screen errors? can you help pleaseeeeeeeeeeeee
    Sergeant:
  • 349 Answers
Do the following: (this checks for a software problem)when booting up press F8 and when you get to the menu, boot up into safe mode,
· then restore the pc back to a date before you had the problem, and/or remove any program or hardware you installed prior to you having the problem,
· run, up to date anti virus and anti spy ware scans
once you have done this and you still have a problem
  • put your windows system disc in the drive ,cancel it if it starts trying to install,
  • then go to start/run type in "cmd" then hit the enter key, when a dos box opens up
  • type in "sfc/scannow" without the "",
  • windows will check all its system files and drivers , and if it finds them corrupted or missing it will replace them.
good luck and let me know how you get on
Terry
Posted on Apr 04, 2008
  • Anonymous Apr 04, 2008
    please rate my efforts
    Terry
SOURCE:
Why does my new HP Win 7 Pro notebook crash on sleep and hibernate?
You may have a registry error.
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 41) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jan 23, 2014 | HP 650 Notebook PC
How can I channge event log if I can't enter set up with F2
if you want to get the event log and the error code
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
hope this helps
Jun 29, 2012 | Computers & Internet
Computer restarts randomly
If you are using Windows (XP, Vista or 7) then open the Computer properties by clicking on the Computer icon (on desktop or start menu) then go to the Advanced page tab and check if you have the option to automatically restart the system set on in the Startup and Recovery Settings section. If this is on, then Windows will restart the system any time that a critical error is encountered.
The other place to check is in the Windows Event logs (system log) provided this option is enabled.
You should be able to access the event logs by right clicking on the Computer icon and then selecting the Manage option followed by opening the Event viewer where you should look for any critical, error or warning entries that may occur at the times when the computer restarts itself (or posted immediately when it restarts).
Jan 12, 2012 | Toshiba Computers & Internet
Windows cannot connect to system event manager
If this problem has not existed for very long try doing a System Restore to a time prior to it starting.
Do you have more than one user profile on your system, if so, have you tried logging in with a different profile to see if the problem exists globaly or just in your normal profile? If the problem is with your profile only then this would suggest that the profile is corrupt and you should create a new profile if you don't have another already.
Another option is to run the System File Checker utility to determine if you have any corrupted or missing critical Windows files.
Lastly try temporarily disabling your AntiVirus and Firewall software then try to access the Event Viewer management console - it is probably best to have your computer disconnected from any internet access when doing this. If this succeeds then check for any events related to the error in opening the Event Viewer - you may find it easier to clear all the current events first then recreate the error and look at the logs again to identify the most current and relevant entries.
Dec 29, 2011 | Microsoft Windows 7 Home Premium 64BIT...
ACER ASPIRE X3910 EVENT ID 41 KERNEL POWER CRITICAL
If it just stopped and restarted proper is nothing to worry cause it seam just like a memory dumping error or so ..If it asks to choose a boot on start ..just start normally or choose to start with the last known configuration that worked.
If it do not want to start it may be a case of corrupted boot file ..and need to repair the boot configuration using a operation system disk or the recovery partition ..My advice is to reinstall a clean copy if it makes troubles again ..It may have something in the system that cause it ..and reinstalling will remove the settings and programs ..and when you install them again try them one by one ..and you will know which one is not supported..
Nov 21, 2011 | Acer Aspire X3910-U3012 (PTSED02010) PC...
My problem is my computer is always reastart in working my opareting system is windows 7
This sounds like a hardware issue, you need to check your error logs and see what is happening. Hard drives sometimes manifest errors like this. The Windows error logs are listed under the EVENT viewer, press start and type event. What you are looking for are errors or critical errors. warnings and information is of little concern. If these logs do not show errors, of significance, hard drive is suspect, again, as failure precludes the error being written to the disk.
Dec 15, 2010 | Computers & Internet
Fujitsu siemens an unexpected I/O error has occured
Hello olamideidowu,
Here is a way to find out what the message means. Look for entries in the system event log that happened on the same day your error message happened.
*Using the Event Viewer:
•Click the Start button on lower left corner of the screen
•Select 'Run' (on Windows XP) or Type 'Run' and press the Enter key (on Windows Vista)
•Type 'Eventvwr' (in the 'Run' box) and click OK.
•(On Windows Vista) open the Windows Logs folder in the left pane
•Select the 'System' log in the left pane
•Look at the system events that happened on the same day as the I/O error. One (or more) of those events should contain the 'unexpected I/O error' message.
•Get the Event ID and look up what it means on the Microsoft Events and Errors Message Center: http://www.microsoft.com/technet/support/ee/ee_advanced.aspx
Also, the 'Message Level' of the event shows as Information, Warning, Error or Critical. Looking at the message level can help determine how serious the event may be. Events that have Error or Critical message levels can indicate a problem on the system.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 05, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
SUMP error in Windows Vista
Try to increase the size of Event Logs files.
Open up Event Viewer by typing in eventvwr into the Start \ Run box, or you can find it under Administrative tools section of Control Panel.
You’ll notice over on the right-hand side of the window that the current size of my Application and System Event Logs are 512 KB…
Now you can right-click on one of the Event Logs in the list, and choose Properties from the menu.
In this dialog you can do a number of things… you could clear the log, increase the size, or just set the system to overwrite events as needed
chose to increase the maximum size of the event log, and then also to overwrite events as needed
For those of you using Windows Vista, you’ll notice that the default settings in Vista are to overwrite as needed, and the maximum size is way bigger. Guess my setting choices make sense then…
Aug 04, 2009 | Microsoft Windows Vista Home Premium SP1...
URGENT CALL: Critical Error that keeps cutting out AOL
GO Here and download the Hotfix at the top of the page.. (click on the Hotfix Icon, and follow directions..
http://support.microsoft.com/kb/937063#
it is for vista home basic as well......
then lemme know again
Jun 11, 2008 | Toshiba Satellite A135-S4527 Notebook
Open Questions:
Computers & Internet Logo
52 people viewed this question
Ekse
Alun Cox
