Question about Hobart N50 Stand Mixer
Hobart N50 Tripped
Hi, I have an older, I think 70's N50 Hobart. Can you please tell me where the trip button is for it? Can I do whole wheat dough in it without stripping the motor gear? And I am thinking about buying a Pro 600 on eBay if I can find a good deal, but does it really have more power than the N-50 (I don't need both and I really love my N-50). Thank you (:
    Scholar:
  • 68 Answers
The reset button is to protect over amping the motor. The N-50 is not a very strong unit, (commercially), but you won't break a gear. If you overload the unit, you'll either trip the overload (reset button), or you will break the taper pin that attaches the planetary to the center shaft.
If you're looking for a small commercial unit, and you're in the US, look into the 10 qt Precision Mixer.
Posted on Apr 25, 2008
SOURCE:
Hi, We have a 3phase Hobart D300 Mixer onboard and the cooks are complaining that there is not enough grunt. I have checked the 3 speeds and they are working finee however when dough is being mixed it...
Hello Veelec,
As the machine is mixing dough it seems that it is getting sluggish. This is caused by the machine being over loaded. Although it is a 30 qt mixer that is for liquid filled capacity. I do not know what kind of dough you are mixing so I will give you a light to medium dough and then the heavy dough capacity. Also on this machine all dough should be mixed in speed 1 or low to keep from damaging the machine.
You will need to know the Absorption Rate (AR) of you dough, to find this you take the weight of the water divide the weight of the water and multiply by 100.
AR = Water Weight / Flour Weight x 100%
The higher the percent the higher the capacity the lower the percent the lower the capacity. Also the temperature of the water will have to be considered as the colder the water the harder the dough it is to mix the dough the batch should be reduced by 15% to 20% for water temperature between 65-75 degrees.
For a Light to Medium dough with a 60% AR the unit capacity is 45 pounds in first speed.
For a Heavy dough at 55% the units capacity is 30 pounds in first speed.
The above capacities are for bread doughs, if you are doing pizza dough, dough nut dough or wheat dough please post back to this thread and I will help you to find the capacities.
I hope that I have helped you with your problem and would like to thank you for using FixYa to find a solution to your problem.
Mar 02, 2011 | Hobart D300 Stand Mixer
Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Jun 04, 2009 | Hobart N50 Stand Mixer
In need of a Hobart N50 spiral hook
Hi. Goto globeequipment.com they have an ED hook for your N50.
If this solution has assisted you, please rate it. ricardok45
Apr 06, 2009 | Hobart N50 Stand Mixer
Which kenwood mixer to buy?
Hi. Congratulations for researching mixers. I wish I had before I bought my Kitchenaid HD Pro. All mixer manufacturers over-rate their products. Goto www.consumeraffairs.com and do a search for each mixer you are considering. Most mixer failures are caused by mixing heavy cookie or bread doughs. Although manufacturers claim that their mixers can easily handle these doughs...They cannot! My Kitchenaid self-destructed after 30 batches of bread dough. "For the way it's made"! Indeed! I solved my problem by buying a Hobart N50 mixer. It's a 5qt. and handles anything I throw into the bowl. I bought mine used, and refurbished it myself. New these units cost $2,035.00 USD.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Mar 15, 2009 | Kenwood KM800 Major Classic Stand Mixer
Hobart L800 making noise
If you can send me your email address i can send you a parts catalog for your L800 They have no way to send a link here is my email address
[email protected]
Feb 20, 2009 | Hobart N50 Stand Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Looking for older Hobart logo for N50 mixer 1965
you would have to have it made not available
Jan 03, 2009 | Hobart N50 Stand Mixer
Hobart N50 repair books
parts books are available at hobartservice.com for free and you might be able to find service manuals on ebay
Oct 22, 2008 | Hobart N50 Stand Mixer
Noisy Hobart N50 Mixer
First, there is a double set screw (one on top of the other - if they are both there) towards the back of the planetary.
Remove the first screw, it should have a normal tip, not pointy. Run the mixer in 1st and adjust the screw, first out then in. Then repeat in 3rd. You should clearly hear a difference.
If not, you probably need to repack the grease in the transmission. The proper grease is called "Darina II". It's expensive ~ $35 per mixer.
Apr 13, 2008 | Hobart N50 Stand Mixer
Motor is not running now
Im a service tech for hobart and repair these mixers often-is it worth repairing the unit?YES it is.I have never seen a motor burn up on these units,i have seen keys sheared and gears broken but thats the extent.There is a overload/reset button that sits on the back of the mixers pedistal,if its tripped when you push it in it will click.when these units need service it is usually from overloading the unit with too much product.Any other questions let me know.
Nov 30, 2007 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
465 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
