Question about IBM ThinkPad R51 Notebook
IBM Screen Rippling Problem
I have having serious problems with screen rippling when scrolling.
Can anyone tel me how to fix this?
    Problem Solver:
  • 28 Answers
You will get a better response if you pay for the expertise we have to offer!
Posted on Jun 24, 2008
SOURCE:
I am at work right now looking for solution to my monitor at home. The screen is so wavy that I cannot read the text very good. My 5 year old plays on the computer a lot. And all of a sudden the other...
Connect the monitor to a different computer (laptop or desktop), to see if the problem "follows" the monitor.
Connect a different monitor to your computer, to see if the video-card in your computer is generating the "wavy" display.
Move any "power-bars" and PC Speakers *FAR* away from the monitor, to eliminate electrical interference.
Oct 22, 2010 | E-Machines eMachines Monitor E15T4
I had to reinstall windows xp and now when i scroll up or down my screen is doing this rippling thing
That is because you haven't reinstalled your Video Driver, and the screen refresh rate is slower than normal.
A simple video driver install will cure that.
Mar 09, 2010 | GPX D1816 DVD Player
There is a rippling on the screen that goes downward and then it goes all white
I have a Acer 17" LCD model: AL1717Ab that had horizontal white lines an inch wide that scrolled downward.
The power board had two bad/bulged caps: 25v 220uf 105c Capxon. Replacing them fixed the problem.
I hear that caps can fail without being bulged. I use a standard type small sewing machine screwdriver
ground & tapered to clean the circut board holes by heating the empty hole with a 25 watt soldering irong
and then shove & twist the awl into the hot hole, which reopens the hole. So no solder ****** is required.
I hope this helps someone somehow. Sincerely Bitdog
Jan 17, 2010 | Acer AL1717 17" LCD Monitor
Rippling effect on Relisys T565 monitor when scrolling
You need to install drivers for your graphic card
Nov 28, 2017 | Relisys TL565 15" LCD Monitor
Mouse, cursor and scrolling problems
HI TRY CHANGING DISPLAY SETTING IF YOU THING IT THE DISPLAY
Dec 03, 2008 | HP Pavilion Media Center a1330n - AMD...
Subtle rippling lines when playing HD
your convergence ICs may be getting weak as they last about 4 years give or take depending on how often the set is ov. The subtle lines may just be a faulty cable or a bad solder joint on the ground of your input board.
Jun 22, 2008 | Televison & Video
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
INSIGNIA TV SCREEN - BLANK ???
the pwr supply is not regulating properly what happens when turned on regulation starts to swing and ripple increases causing lines in image panel....john
May 27, 2007 | Insignia IS-LCDTV32 32 in. Television
IBM ThinkPad R51 Notebook Logo
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
