Question about HP Photosmart C7180 All-In-One InkJet Printer
HP photosmart c7180 scanner failure
My hp printer is not allowing me to scan copy and fax it is saying scanner failure i contacted hp about this and thay refused to replace it unless i pay 269.00 for a replacement because it was a week out of warranty please help
  • Anonymous Apr 05, 2008
    Same problem - although I am still under (extended) warranty - I have not yet called for support.
    An expert who has answered 20 or more questions within one hour.
  • HP Expert
  • 105 Answers
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at:
good luck...
Posted on Jun 13, 2008
    Problem Solver:
Hi my HP photosmart C7180 say unable to scan, copy or send a fax.
Posted on May 24, 2011
I can not scan from my HP Photosmart C7180 All in one. Mac OSX 10.6.8 I can copy, print but not scan.
Launch the OSX system preferences, click on the Print & Scan Icon located in the Hardware row, select your printer in the left hand column, click the Scan button above the right hand box, click on the Open Scanner button, a new window will open, click on the scan button in the upper right hand corner of that new window, set your document on the flat glass panel of your multi function printer/scanner, and click the scan button located in the lower right hand corner of the window, once scanning is complete, your document image should appear in a new window and save the image from there.
Dec 22, 2013 | HP Photosmart C7180 All-in-one Printer Fax...
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Error msg says scanner failure.
ensure the printer was correctly enstalled, check all connections ensure a tight fit. if it is connected to a network make sure the network cable is plugged in and blinking green
Nov 03, 2009 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C7180 won't print!! I had an IT person come to my home earlier today, and it was printing when she left. Not 20 minutes after she left, it wouldn't print for me!!! This is the second time...
It would seem that your default 'printer' is set to fax and not print.
When you select print from the file menu it probably says something like HP Photosmart C7180 Fax in the printer option. If it does, go into the printer section from the control panel and make the C7180 (without the fax reference) the default (right click>set as default)
Oct 15, 2009 | HP Photosmart C7180 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP C7180 All-In-One (Fax)
Does it say Scanner Failure...?
If then try these steps mentioned bellow:
Remove all the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is above the place wher we install ink cartridges it is a metal part which moves in a metal bar) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then if it prompts the ink cartridges insert ink cartidges
Now try printing a test page or make a copy
If it still makes a loud noise and the message comes up as scanner failure, then either the scanner or the scanner machanisum is bad, you may have to replace the unit
Good Luck
Sep 01, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP shotosmart 3310
i cannot scan any documents
Jul 17, 2008 | HP Photosmart 3310 Printer
Hi try coping a document from the machine and see if the copy comes out with these lines. If it does then the machine scanner unit is faulty and will need replacing. If not then the likely thing is that the printer device drivers are incorrect or faulty. reinstall the drivers or download a up to date driver from for the other printing darker try changing the graphic processor mode in the driver. Goto printers and faxes right hand click on the printer icon and select properties.
Once in properties select the advanced tab at the top of the windows within this tab at the bottom select print processor. Once in there choose another graphic mode OK close and test if no improvement select a different one and so on until improvement is achieved. if no improvement then reinstall the drivers if you haven't already.
Hope this helps
Thanks J
Nov 29, 2007 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
1,556 people viewed this question
Ben Johnson
