Question about Samsung Washing Machines
I have a samsung front load washing machine wf316las with an error code PF. please help
WF316LAS
In the washer owners manual it shows "PF" code with the following explanation.
Meaning
Electric service was lost when the washer was running.
Solution
Restart the cycle by pressing the cycle selector dial.
I hope this helps a little bit.
Posted on Apr 21, 2008
SOURCE:
How do you fix the maytag neptune pf code for the dryer??
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Codefor Appliances
heatman101
Apr 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Where is the debris filter on a Samsung WF316las/xaa?
There is no more filters to be cleaned on front load machines. It's a self cleaning filter and everything goes through the drain.
Mar 14, 2011 | Samsung WF337AA Front Load Washer
Getting a beeping signal with a code message PF
PF Error Code for Appliances
heatman101
Jan 24, 2011 | Kenmore 46472 Front Load Washer
I have a Samsung WF316LAS/XAA Washing Machine, has worked great for 4 years. Just started pouring water out of the soap dispenser drawer when in a washing cycle. Any advise
take off the top and check the hose that leads to the tub may be plugged . May have to take the boot(door)seal off front under door to access lower end.
Nov 20, 2010 | Samsung WF306BHW High Efficiency Front...
We are getting an error code of "PF" and can't
heatman101
0-=0
Oct 31, 2010 | LG WM3431 Front Load Washer / Dryer
PF code when on spin cycle
heatman101
Oct 15, 2010 | LG WM1814CW Front Load Washer
HAVE LE CODE ON SAMSUNG WF316LAS/XAA WASHER LE CODE AND BEEPS
LE is a water level issue.
- The part of the hose where the water level sensor is
located is damaged (punctured).
- The hose is clogged with foreign material.
- The hose is folded.
- Too much lubricant has been applied to the insertion
part of the air hose.
- Hose engagement error (disengaged)
- Part fault (Faulty internal soldering)
- The water level sensor terminal is disengaged.
- Main PBA fault.
Dec 19, 2009 | Samsung WF316BAC 3.79 cu.ft High...
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Jan 29, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
370 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
