Question about Lands Phones
Cannot connect to base. I have followed the procedures in my operating book and cannot make it work.
    Master:
  • 351 Answers
Dear Jnelmil,
Please provide the details of Phone, so that we can try to solve your problem accordingly.
Takecare
Posted on Apr 04, 2008
6ya staff
SOURCE:
I have Panasonic kxtc1237sud. When I press the talk button, the following message is displayed "No link to base ..." How can I link the hand set with the base? Thanks!
follow the procedure to register the hand set to the base ( all in the user manual)
get closer to the base ,
change the battery --too low to send a strong signal
move away from metal walls etc
no link means not wireless connection
Apr 07, 2017 | Panasonic Lands Phones
ABS light and traction light and no cruise control
how on earth would the blind know what is wrong.?
scan it? yet?
btw, newer cars cut cruise feature for any signs of danger.
new laws...
the traction needs ABS to work ,so forget that and fix ABS.
ABS needs 2 things to work , brakes and ABS.
so if brakes are bad, then ABS will get upset.
after all, if it cant brake right, how can the puter save you?
if brakes are known to be ok (inspections work here)
but in this case it was BREACHED by you, with out reading the book first.
then scan the ABS. (omg? code for dead sensor?) nah, you caused it..
easy
ABS resets every key on. so...
my guess, if ABS was happy before your actions( you never said)
then you got air in to the system. and failed to follow the FSM instructions on bleeding brakes, in ABS car.
front caliper, did you block the hose with cap, so it didn't allow air to the modulator? oops... never just let them drip... or . max pain.
bleed it again, (using any or all 5 ways to do so, bleeding is skill thing) (many modulators can not just be simply bled)
now Ill quote the 2012 fSM for you , under brakes
Data: -----------------------------------------------------------------
ABS Brake Bleeding
STANDARD PROCEDURE - ABS BRAKE BLEEDING
ABS system bleeding requires conventional bleeding methods plus use of a scan tool. The procedure involves performing a base brake bleeding, followed by use of the scan tool to cycle and bleed the HCU pump and solenoids. A second base brake bleeding procedure is then required to remove any air remaining in the system.
Perform base brake bleeding, (Refer to Brakes - Standard Procedure)(Refer To List 1).
Connect scan tool to the Data Link Connector.
Select ANTILOCK BRAKES, followed by MISCELLANEOUS, then ABS BRAKES. Follow the instructions displayed. When scan tool displays TEST COMPLETE, disconnect scan tool and proceed.
Perform base brake bleeding a second time, (Refer to Brakes - Standard Procedure)(Refer To List 1).
Top off master cylinder fluid level and verify proper brake operation before moving vehicle.
Jul 31, 2015 | 2012 Jeep Liberty Sport 4dr SUV 3.7L V6...
How many hours to remove an engine of a 84 harley per glide
Book time is 4.0 hours to remove and replace the engine. Book time is based upon the average for performing the operation 10x' s by an experienced tech. Be aware that all rubber mounted engines (Dynas, Touring) must have the drive train realigned when the engine is removed and replaced. Absolutely and positively don't do this job without the service manual, correct tools, and torque wrenches. Also note that the cylinder torque procedure in the service manual does not work and results in oil leaks and cylinder head blow-by in most cases.
Jul 15, 2014 | 1993 Harley Davidson FXR Super Glide
My phone looses connection very often. it brings up a message saying your answering modem has been disconnected to please check your settings
Try the following, (may work)
To manually select the network operator to use for data connections
You can also manually select your network operator from Connection Setup's
settings screen. Connection Setup will then reconfigure your device's data
connections settings based on the operator that you selected.
1. On the Home screen, slide to the Settings tab and then tap All Settings.
2. On the Connections tab, tap Connection Setup.
3. Select the network Country and Operator you want to use, then tap OK.
Note If you choose a Country and/or Operator that is different from the installed SIM
card network operator, you may not be able to access network services.
4. When prompted to confirm whether you want to configure the data
connection settings based on the selected network, tap Yes.
Connection Setup configures the data connection settings.
5. After the Connection Setup completes the configuration, tap Restart.
May 03, 2011 | HTC HD2 Smartphone
Need sequence to blrrd brakes 02 dakota
Dakota, 2001-2005
Bleeding the Brake System
Brake fluid tends to darken over time. This does not necessarily indicate contamination. Examine fluid closely for foreign matter.
The primary and secondary hydraulic brake systems are separate and are bled independently. During the bleeding operation, do not allow the reservoir to run dry. Keep the master cylinder reservoir filled with brake fluid. Never use brake fluid that has been drained from the hydraulic system, no matter how clean it seems.
  1. Clean all dirt from around the master cylinder fill cap, remove the cap and fill the master cylinder with brake fluid until the level is within 1 / 4 in. (6mm) of the top edge of the reservoir.
  2. Clean the bleeder screws at all 4 wheels. The bleeder screws are located on the back of the brake backing plate (drum brakes) and on the top of the brake calipers (disc brakes).
  3. Bleeder screws should be protected with rubber caps. If they are missing, the orifice may easily become clogged with road dirt. If the screw refuses to bleed when loosened, remove it and blow clear. Aftermarket caps are readily available.
Bleeding the ABS System
This is accomplished using the same methods as for the base brake system. Refer to those procedures.
ABS system bleeding requires conventional bleeding methods plus use of the DRB scan tool. The procedure involves performing a base brake bleeding, followed by use of the scan tool to cycle and bleed the HCU pump and solenoids. A second base brake bleeding procedure is then required to remove any air remaining in the system.
  1. Perform base brake bleeding. Refer to the appropriate section.
  2. Connect the scan tool to the data link connector beneath the dashboard.
  3. Select "Antilock Brakes" followed by "Miscellaneous", then "Bleed Brakes". Follow the instructions displayed until the unit displays "Test Complete", then disconnect the scan tool and proceed.
  4. Perform a base brake bleeding a second time.
  5. Top up the master cylinder.
Hope helps (remember rated and comment this).
Aug 26, 2010 | 2002 Dodge Dakota Club Cab
Panasonic KX-TG1100
yes!
sorry, it seems that they have no manual for this model base online yet. however, the procedure to reset handset numbers for the 1000N may work for you. there is a 15 digit number on the base unit. type that into the handset using the book (was on page 54 for the 1000n) for your 1100 and see if that will register the other 1100 to your base.
Nov 26, 2008 | Panasonic KX-TG1100 Cordless Phone
Can I get the asswer for the below questions
A book shop maintains the inventory of books that are being sold at the shop. The list has details like author, title, price, publisher and stock position. Whenever a customer wants a book, the sales person inputs the title and author and the system searches the list and displays a suitable message if it is not available. If it is available, the system displays the book details and requests for the number of copies required. If the copies are available, the total cost of the copies requested is displayed, otherwise the message ‘copies not in stock’ is displayed.
Design a system using a class called BOOKS with suitable member functions and constructors. Use new operator in constructors to allocate required memory space.
Nov 16, 2008 | Computers & Internet
E4 error code
Exact same problem. E4, sent uniden an email thru their website though I doubt Ill hear any response. Very disappointed as the 9485 was working great until all of a sudden E4 showed up.
Nov 29, 2007 | Uniden TRU9485 Cordless Phone
"searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Jun 03, 2006 | AT&T 2256 Cordless Phone
Lands Phones Logo
69 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
