Question about Jl Audio 500/5 Car Audio Amplifier
Ignition noise when playing a cd, in quiet passages I hear ignition noise like a whine, and it increases with engine speed, plus the sound is crackling
    Sergeant:
  • 300 Answers
The sounds you are hearing are usually due to one of two things:
  1. The RCA preamp cables between the head unit and amp are either run too close to the +12V line or the connectors are touching a metal object.
  2. The ground connection is too long or not as clean/solid as it should be.
To fix problem #1, just make sure the RCA lines are on one side of the vehicle and the power is on the other.
To fix problem #2, make sure your ground connection to your amp is as short as possible (ideally <2ft) and is tied to a clean (ie no dirt, paint, grease) point on the chassis.
If the issue still exists, search the web for a ground loop isolator.
Posted on Apr 04, 2008
Why do i hear my fuel pump on a 2004 pontiac bonneville whining up and down?
Walt, You will hear the fuel pump at times. When you take the gas cap off the fuel tank is acting somewhat as an echo chamber that is amplifying the noise of the fuel pump. Presumably the engine is ticking over when you remove the gas cap? Otherwise the fuel pump should not be running.
The fuel pump only supplies fuel on demand - obviously. The pump will run to pressurise the system to meet demand and if that demand for fuel fluctuates, the pump will run down or increase speed accordingly. This speeding up and running down of the pump is constant.
If by 'a miss' you mean that the fuel pump goes quiet for a second or so - that's normal. No demand for fuel - the pump doesn't run. That wouldn't effect the engine at tickover.
If the 'miss' is from the engine at tickover that's more than likely to be a plug.
If your car runs okay at speed and doesn't cut out and then will restart almost immediately, it sounds as though your fuel pump is okay.
Mar 21, 2016 | 2004 Pontiac Bonneville
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
I have a 2009 BMW X5 and its making a crackling noise in the engine. When I accelerate it goes away but is present when the vehicle is stopped or at low speeds. Please help
The crackling sound you hear is called pre-ignition. Meaning your either running too cheap a fuel or the engine needs timing reset because timing is too far advanced and causing pre-ignition. That means the spark plugs are firing earlier than they should.
Aug 22, 2013 | BMW X5 Cars & Trucks
I AM INSTALLING A SYSTEM ON MY 1995 NISSAN ALTIMA WITH AN OLD ROCKFORD 360X6 AMP AND NEW ROCKFORD SPEAKERS HAVE TRIED A ROCKFORD PRIME R300-4 AMP WITH EVEN MORE IGNITION NOISE QUITE A LOUD WHINE INCREASES...
Hello my name is Israel and I will try to help you out. I have read your problem and what stood out was where you hooked up an ipod and no noise was heard. Do you hear noise when a cd plays? Do you hear noise when the radio plays? When else do you not hear noise?
Feb 23, 2011 | Kenwood DDX516 Car Video Player
Whining noise from front of 2003 impala.higher
Apparently the whine is car speed related and not engine speed. I'm surprised that you didn't say anything about checking the wheel bearings?
Mar 22, 2010 | 2003 Chevrolet Impala
2002 dodge durango whinning noise will your
Thank you for getting back to me. I would like you to check your transmission fluid. start the engine and let it warm up at idle speed for about 15 min and check the fluid. It sounds like you do not have enough in it, there for the whining noise with increase of speed since your transmission is speeding up with the rate of your vehicle. If this does not help and the problem persist please let me know. If the noise you were hearing was coming from the u joints of the vehicle it would not make a whining noise with increase of speed. The u joints will only make a noise when they are going bad when the vehicle is shifted into any gear from the shifter( EX: park to drive, park to reverse ECT.)
Jan 09, 2010 | 2002 Dodge Durango
Whining from engine when in gear
Just a thought- remove the oil filler cap when the whine is present - (this checks if PCV valve is faulty, causing high crankcase vacuum, which in turn causes a whistling/whine noise as air leaks past engine oil seals). Worth a check.
Try listening with a short piece of hose pipe to locate immediate area/source of noise.
Jun 17, 2009 | 1998 Dodge Ram 1500 4WD
Whining noise when the engine running
Yep, That was it. i followed a link to trailvoy.com and found a video with the same noise and links to how to repair. My husband fixed it yesterday and the noise is no more!! Good Luck..
Apr 11, 2009 | 2006 GMC Envoy
2004 lincoln aviator having a strange whining noise from the engine
I have an 03 and around 30,000 miles the same thing happened to me . I took it to the dealer and the replaces the idler pully wich is what was making the noise .hope this helps you
Aug 31, 2008 | 2007 Lincoln Aviator
Jl Audio 500/5 Car Audio Amplifier Logo
115 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
