Question about Samsung Digimax S730 Digital Camera
DIMAGE Z10 MY PICTURE CARD SAYS LOCKED AND I CAN NOT FIGURE HOW TO GET IT UNLOCKED
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Mar 09, 2010
6ya staff
SOURCE:
Dimage Z10 won't read card
What type and size card? The Z10 uses SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Jun 29, 2013 | Photography
Konica minolta DiMage Z10 doesn't recognize sd card
Might one enquire how you have assessed the intelligence of the connecting lead ? I know of no definitive tests for this area of electronic equipment.
Mar 16, 2017 | Konica Minolta DiMAGE Z10 Digital Camera
Mesage "unable to use card"
SD Memory Cards have a write-protect switch to prevent image
data from being deleted. By sliding the switch to the bottom of
the card, the data will be protected. images cannot be recorded
when the card is protected. If an attempt is made to record or
delete an image with the camera, the card-locked message will
appear on the monitor.
Sep 21, 2011 | Konica Minolta DiMAGE Z10 Digital Camera
Konica Minolta DiMAGE Z10 no sound?
because this particular model of the Z series does not have a mic. recording. kind of a waste but if you went to another model (I.E.. Z2) it does have the mic. to record. sorry but i went through the same issue myself. good luck
Mar 18, 2009 | Konica Minolta DiMAGE Z10 Digital Camera
Compatibility of sdhc card with konica milota Dimage Z10
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Nov 28, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Unable to Use Card
My Z6 does the same thing every now and then.
The only way I can get the message to stop (and that annoying warning chime) is to pop the card in and out real fast with the camera turned on.
It seems as though these Konicas are REALLY picky with the cards, and this is a well known issue. Also, make sure the little "lock" tab is in the "unlock" position.
You can also try taking the batteries out, and holding the on/off button for 1 minute. That resets it back to factory defaults, and clears out any "bugs". Sometimes it helps.
Sometimes using a card reader and manually formatting the card works too.
Apr 06, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
KM DiMAGE Z5
Try using a different Memory Card.
Then try takeing the batteries out overnight to let the camera reset.
Otherwise I dont have good news options. Sounds like It would be something internal that wouldnt be cost affective to fix.
Hope its the Memory Card,
Caleb
Mar 25, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
Samsung Digimax S730 Digital Camera Logo
48 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
