Question about Gaggia Syncrony Compact Digital Espresso Machine
The machine is showing the brew unit is blocked but we have taken it out and cleaned it but this makes no difference.
  • Mr Fixit Aug 14, 2010
    Question: When you reinstall the brew unit, does it click into place?
    When you pull out to remove it, push on the thumb switch. But when you replace it, do NOT hold the thumb switch.
  • 21 Answers
Does the brew unit try to move at all? You can listen for the motor, or open the door panel and defeat the safety interlock while it's operating. (Be careful not to put a finger in there.) Then you can observe where the brew unit is getting stuck.
Posted on Aug 14, 2010
SOURCE:
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the...
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jul 30, 2014 | Jura Capresso Impressa F7 Espresso Machine
No coffeer comes out of the coffee spouts, maybe the steel filters are dirty, how can I cean them?
Before the instructions on how to clean the filters, Check the grinder to make sure is set properly.
It might be set too fine
Cleaning the brew unit filters
Wipe away any coffee residues from the steel filter in the funnel of the
brew unit with a sponge.
The chrome filter to the left of the funnel can be removed for thorough
cleaning. Check and clean the chrome filter regularly.
^ Remove the brew unit.
^ Fit the enclosed allen wrench (that you got with your machine) to the
connection point (see illustration in your manual) in the brew unit. Turn it
counterclockwise while supporting the chrome filter from below.
^ Remove the chrome filter with the screw.
^ Clean the filter with hot water and dry.
^ Return the chrome filter to the brew unit and secure it by turning the allen
wrench clockwise. Press slightly against the filter to allow threading.
Jan 18, 2011 | Miele Coffee System
Syncrony Compact Digital unit- Used well for 5 yrs without incident. Currently, after bean grinding and tamping stages, a strange, non metallic rumbling/grinding sound occurs just before the...
First clean the screen and tube on the brew unit, then lube the guides/gear grooves on the brew unit, also lube the o-ring(big red one). Then that should take care of it. You can also try backwashing/degreasing the brew unit if the machine has a preground chute.
Feb 07, 2010 | Gaggia Syncrony Compact Digital Espresso...
Hi thanks for the imfo but just cleaned brew unit and greased all
The main board has failed.
This occurs when the brew unit is too tight and not lubed up.
It damages drive components on the main board.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Brew draw blocked
Ok if brew unit is displayed,the cause is the brew unit needs to be to cleaned of all old grease and coffee grounds.
Once cleaned you will need to regrease the big oring at the top of the brew unit,pretty much anywhere that moves needs to be lubed and the two smaller ones near the back of the dreg drawer.
In some cases a tight or siezed brew unit can damage the main control board.
Feb 02, 2010 | Gaggia Titanium Espresso Machine
Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Jan 03, 2010 | Gaggia Titanium Espresso Machine
Grinder blocked
Check the chute from the grinder to the brew unit.
Oct 06, 2009 | Gaggia Titanium Espresso Machine
I have water leaking from under and I cannot see where it is from. I have taken the brew group out and cleaned but it still appears.
try this:move brew unit and you will see white brew valve,clean inside sometimes coffe stuck inside and dont draining water from valve in tray
Aug 20, 2009 | Saeco Vienna SuperAutomatica Coffee...
Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Gaggia Syncrony Compact Digital Espresso Machine Logo
598 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
