Question about Kitchen Ranges
Freestanding Electric Maytag Stove /Oven (with 4 burners self clean w/clock)
The oven turns on only for the clean cycle; but does not turn on for regular baking/broiling. Unit is about 6 years old.
  • Anonymous May 13, 2008
    could i get a acopy of the oven door assembely? mine wont close.
  • Anonymous Jun 23, 2008
    We've had this happen twice after the power went out during an electrical storm. The display shows an F9 code and the oven door locks. My husband manually unlocked the door and it worked fine after that. It happened again last night and it won't unlock this time. Any suggestions?
    Novelist:
  • 184 Answers
I WOULD LOOK AT THE DOOR LOCK ASSEMBLY AS THE DEFECT. THERE IS USUALLY A SWITCH THAT TELLS THE CONTROL IF THE DOOR IS LOCKED OR NOT. IF THE SWITCH HAS SHORTED CLOSED, THE CONTROL THINKS THE DOOR IS LOCKED AND WON'T DO ANYTHING BUT CLEAN.
MOST OF THE ASSEMBLIES ARE UNDER THE RANGE TOP.
YOU MAY HAVE TO REMOVE TWO SCREWS FROM THE UNDERSIDE OF THE TOP AT EACH OF THE FRONT CORNERS. OPEN THE OVEN DOOR TO GAIN ACCESS.
IT WILL BE LOCATED IN THE CENTER. THE DOOR HOOK THAT STICKS OUT TO ENGAGE THE DOOR IS PART OF THE DOOR LOCK ASSEMBLY.
Posted on Apr 04, 2008
The burners on my Maytag electric stove work intermittently. Advanced cooking system Super capacity model.
If intermittenly you mean they quit glowing at times is how mine work also and wife does not say they don't cook alright but they do turn off and on as heat requirement changes
Jan 11, 2015 | Maytag Gemini 30" Self-Cleaning...
Maytag oven problem
Somehow, usually when cleaning the face of the clock area, you locked the oven control. Go into your manual, and it will tell you how to unlock it. If I remember right, try holding in the broil button for 5 seconds, that might take it out of the lock mode.
Apr 04, 2008 | Kitchen Ranges
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
2 of the 4 burners on my maytag gas stove aren't working. the oven is fine, just need to know where to light the pilot
Most newer Ranges don't have a pilot ... they have an electronic ignighter. When you first turn the burner on ...you hear the spark going crack,crack
Feb 20, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
We have a frigidaire self cleaning oven . It made a bang and now there there is no power to my oven. Clock does not work , Burners on stove still work.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
Jan 21, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Jan 28, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
316 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
