Question about Mitsubishi WT-46809 46" Rear Projection Television
Green light turns on, then tv switches off
So what do I do next? Is there some sort of reset process?
Thanks
drh2o
  • MATT BECKER May 11, 2010
    try pressing the MENU and DEVICE(or INPUT) button on the front panel after the tv has shut off. hold them together for about 8 seconds or so. it will start to blink there will be one set of blinks then it will pause then you will get another set. this is called an error code. depending on what error code it gives you we can go to the next step.
  • 927 Answers
TRY THIS WITH MODEL:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
GOOD LUCK, big IRISH.... OR CALL FACTORY AUTHORIZED SERVICE CENTER.
Posted on Aug 06, 2008
Turned off cable box but did not turn off tv. storm came throuht last night green light next to reset button flashing. tv want turn off or on. tried to reset want reset. unplug tv for a while pluged in...
rforester,
This model Mitsubishi has some capacitor problems with the DM board and the power supply. See my tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains the problem and where to get the parts to repair your unit.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 26, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Daytek television will not turn on.
There is a manual switch on the bottom of the TV. Flick it on and TV screen should come on. The power light will come with this switch off but the screen won't. It had me cursing for a while until I saw the little switch.
May 15, 2010 | Televison & Video
Sharp aquos 42 won't turn on even though the green light is on, turns on for a second then goes black, but green light is still on, if you turn off and on for about 20 times it eventually stays on
Call 877-332-7867 and allow the customer service representative to create a case file for you. Next ask to be walked through an INIT/factory reset. You will need two people unless your tv is plugged into a surge protector that can be switched on and off with your foot because the first step will be to unplug the television or switch off the surge protector it is connected to. The next step is to hold down two of the buttons on the panel while plugging the unit back in/switching tbe surge protector back on with your foot.
May 05, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Television will not respond to panel power switch or remote
This unfortunately has become a widespread problem with this series of Mits televisions. You can read a forem about it here: Flashing green light of death But there is hope, Mitsubishi has instituted a rebuilding program for the chassis inside of your television. Any authorized Mitsubishi repair center should know about how to get you set repaired. It's not cheap (expect $500-$600) and it takes a few weeks, but it will save your TV.
Apr 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
There is a switch on the bottom of the unit that has to be turned on. The power light will come on but not the screen until the switch is on.
Mar 27, 2010 | Televison & Video
It wont turn on
you may have to reset it place a pin in the reset switch (usually next to the memory card) for 15 seconds, hopefully that will sort the problem, good luck
Aug 26, 2009 | Tomtom ONE GPS Receiver
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Red light on display not green as usual no power
Hold down the "input" button and "volume -" button while the MAIN POWER BUTTON IS OFF. Then turn on the main power button while those are held down, the light on the tv & avc box will turn green. When it turns green, immediately let off the 2 buttons and press "volume +" button, then press the "Main Power" button. Next step is to repeat the process about 20-40 times & the TV WILL WORK!. I have read that this may have something to do with the energy star compliant commands that can changed through the serial port.
The above is from psxpirate25. Thanks!
I had to repeat the whole process a couple of times to get rid of the factory setup firmware mode. Do it 40 times, I would mess up the sequence a couple of times. Keep trying, it does work.
May 30, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
May 27, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Mitsubishi WT-46809 46" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
