Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
Leaking out of door
I have read that others have had the same problem - water leaking out front door when the arms are rotating. this is the second dishwasher that has done this- I returned the other. Am I doing something wrong? I have it sitting in the middle of the floor all hooked up and leveled out...and it still leaks.
  • Ron Coons
    Ron Coons May 11, 2010
    complete model num please
    Scholar:
  • 111 Answers
THE ISSUE IS JUST THAT YOU HAVE THE MACHINE COMPLETELY LEVEL CONTRARY TO POPULAR BELIEF DISHWASHER ARE NOT DESIGNED TO BE IINSTALLED COMPLETELY LEVEL U NEED A SLIGHT INCLINE FROM FRONT TO BACK ABOUT A 6 TO 12 DEGREE PITCH BACK. THIS IS BECAUSE THE DOOR DOESNOT HAVE STRONG GASKETS ON THE BOTTOM OF THE INSIDE PANEL. BY PERFORMING THIS TASK YOU WILL ALLOW THE WATER APON ROTATION TO TO HIT HIGH ON THE DOOR AND ROLL BACKWARD AND NOT HIT THE BOTTOM GASKET DIRECTLY ON ROLL OUT OF THE DOOR
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
SOURCE:
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
I have a kitchenaid dishwasher model KUDMOITJBLO installed as new unit in Oct. 2002 in a new home. Current problem is water coming from front door, bottom as unit starts wash cycle after filling. Leak is...
Hello, Thank You for using FixYa. I will be helping you today.I would start by removing the outer door panel remove the screws around the inner door to do this.Then close the door and start a cycle. Sometimes you can see obvious signs of leaks just by removing the panel too. But if not let it run and see if you see water leaking anywhere. You will see water in the bottom corners its normal. If water is splashing over those corners the check the lower spray arm gor damage or cracks it can cause this problem also make sure the screws under the spray arm are tight. also check the upper arm.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
Seal round door leaks
If the water is noticed at the bottom of door it is probably the seal at the bottom (very unusual for the tank seal to leak, however it is just pushed in, so you could take it completely off, give it a clean up and put it back in) or one of the spray arms is restricted and instead of rotating the water is spraying continually at the corner of the door. Check all hole in the spray arms are clear and if you have a dishwasher freshener make sure it is not stopping the top spray arms rotation field. You could also check that the top arm is clear to move when your dinner plates are in the bottom basket (the top basket could have been moved inadvertently to the lower level).
Hope this gives you a starting point for checks.
ps bottom door seal is quite tricky to replace, so you may need to get an expert is the above tests indicate that that is the leak source.
Jul 11, 2010 | Bosch Dishwashers
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
My Kenmore stand alone dishwasher leaks. the water seems to come out the front at the bottom of the door. i have cleaned the seal, but it doesn't seem to help. Any ideas?
the spray arm is clug in the hools or your spray arm stuck, put the spray arm in a position you remember run the machine for few second and open the door to see if the arm move.
Jul 13, 2009 | Kenmore 17822 Free-standing Dishwasher
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Fisher and paykel 913T soft touch dishwasher leaking
They do not have bottom seal, problem possibly is door cabinet seal or loose dispenser leaking, just had that problem woth one of those the other day
Aug 31, 2007 | Dishwashers
Candy
"e" is economy wash and the other buttons are temp selection. i suspect that the problem may be the spray arms not rotating. open bthe door when on wash and check the arms are rotating. if not, remove the arms and clean - they tend to get blocked over a period of time. the arms only rotate with water coming out of angled jets at the end
May 18, 2007 | Candy 24 in. CD950 Free-standing...
Figidare dishwasher
Maytag MDB4000AWW dishwasher:
Neither bottom or top arms seem to be rotating during wash cycle and dishs do not come out clean!
Wayne Wheeler
Jan 24, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
105 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
