Question about Amana AFD2535DES French Door Refrigerator
Amana Refrigerator Problem
I just bought an amana afd 2535 refrigerator and I am having trouble getting it through the doors in my kitchen. It will fit, but gets hung up on the door handles. Is there a way to remove them and then put them back on?
    President:
  • Amana Master
  • 2,651 Answers
Ther should be a small allen screw holding them on no?? if not grabbig the handle and lifting straightup will undo front the clips and ssnap them back on when in. I thihk id rather remove the dorr assy though, (3) 5/16 screws under the top hinge covers, adn by pullinf outh the freezer door youll see 2 phillips head screws bout 5 inches in on either side from the rfornt panel of door located in the sliding track itself, after reemoving the screw the entire door will lift off and out, you gain another 3-5 inches that way and not worry about scratchin the appiance going through doorway
Posted on Apr 04, 2008
6ya staff
SOURCE:
Heating around door gasket
Here is a tip that I wrote about the reasons why the sides and/or seals could be getting hot on your refrigerator.
Refrigerator Trouble The Outside of Refrigerator Hot
heatman101
Oct 26, 2010 | Amana ASD2628HE Side by Side Refrigerator
Humming sound about every 3 minutes for the last few weeks. Today the temperature is 30dg. in freezer and 39 in refrig section. This refrig was bought in June, 2005 and after 1-1/2 year had to have the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 09, 2010 | Amana AFD2535DES French Door Refrigerator
GFCI on refrigerator circuit cuts off.
Yes. Refrigerators should not be on gfci protected circuits. They should have a dedicated 120v circuit .If your kitchen is new enough to be wired with gfci breakers ,it should also have an outlet dedicated for the refrigerator.
Dec 05, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Refrigerator door gasket needs replacing.
yes.. costs is about $100.00 for a gasket (bought from an appliance store- add 4-6 hours of frustration trying to get the [email protected]#$%^&* gasket to seat flat against the door frame.. Then call the appliance store.. probably about another 75-100$ to have them do it..
Sep 27, 2009 | Amana ABB222ZDES Bottom Freezer...
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Vegetables frozen in vegetabe drawer
your refrigerator door (ajar) check coldcontrol
Mar 01, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana fridge door on wrong side
Generally, doors can be swapped side to side.  Look for some kind of plate where the hinges would be on the other side of the box from where you've got the door mounted now.  It may be covered with a plastic piece.  If you find it, you're in business.  A small socket set is all it usually takes.  Get help holding the door in position as you do the work.  Doors are heavy.
Nov 12, 2008 | Amana ARB2257CSR Bottom Freezer...
Amana AFD2535DES French Door Refrigerator Logo
231 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
