Question about Canon PIXMA iP1800 InkJet Photo Printer
PRINTER DON'T HAVE SOFTWARE TO INSTALL PRINTER TO MY COMPUTER & NOT LISTED ON THE COMPUTER
  • 236 Answers
You can download the drivers for your printer for Windows 2000/XP/Vista from thier site:
Here is a direct link to the driver
Posted on Apr 04, 2008
SOURCE:
Brother mfc 7420 software won't install
First unplug the printer from the computer. Go into the device manager, under system in the control panel. You should see some devices listed as unknown device or it may have the printer name with a yellow exclamation mark by the name. Delete any of these that you see. Leave the printer unplugged and restart the computer. When it boots up reinstall the printer software and don't connect the printer until the software says to. It should go right through the install now.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 10, 2012 | Brother MFC 7420 All-In-One Laser Printer
Tip
Printer not Printing
Check the hardware and software settings first
1) Check the Hardware Connection -
a) Power connection to Printer
b) USB Connection from Printer to Computer
2) Checked the Drivers Software
a) XP/Vista = Open the device manager
Click Start - right click on My Computer
Click on Manage
Click on Device Manager
Click on (+) Ports COM & LPT and Check wheater the Printer is listed or not
or
Check for Printer Name which ever you are using is it listed if YES - Check by printing the test Page
if NO - Install the Printer Drivers and then print the Test page
on Jan 21, 2010 | Office Equipment & Supplies
I need to install my printer on a computer How do i do that ?
Hello paladin41
It is recommended to install first the software ( use the cdrom and follow instructions ) BEFORE connecting the device to the pc . If you don't have the cdrom , you can get the software/driver , free of charge , from here : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1141647&lc=en&cc=us&dlc=en&lang=en&cc=us
attention : select the correct OS before downloading .
Best regards ,
fanaudi .
May 08, 2011 | HP Photosmart C4180 All-In-One InkJet...
I cannot seem to install my printer ... can you help?? I have an HP Pavilion desktop a 1620n and my printer is an hp psc 2175 all-in-one printer* copier* scanner
if you already install the driver
kindly uninstall the printer driver and software restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt you for connect the usb cable then connect it and follow the instruction. It will resolve your problem.
Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Feb 03, 2010 | HP PSC 2175 All-In-One InkJet Printer
Hardware
Click on Manage
or
MY LEXMARK X550 PRINTER WILL NOT INSTALL. I HAVE
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Nov 17, 2009 | Lexmark X2550 All-In-One Printer
My picture will not scan to the computer
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Nov 16, 2009 | Lexmark X2500 All-In-One Printer
I can print but computer cannot find scanner.
Sep 21, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Computer won't recognize printer
Try each of the USB ports on your computer.
Assuming that you have a USB-cable between the computer and the printer, unplug the USB-cable from the computer, and connect some other USB device (iPod or memory-stick). Does Windows detect that other device? If not, then you need to install the correct software device-drivers for your USB ports.
Is the printer properly detected when connected to some other laptop/desktop computer?
Sep 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
HP Deskjet 840c - Printing Emails
I did see you reinstalled your software) but please continue
It is important that you have that icon by the clock. Power off the printer by pressing the power button on the printer.
Please un-install your printer software through Add/Remove Programs within the control panel. Please restart the Pc after un-install is complete. Create a folder on your hard drive and name it, "HP DeskJet 840C". Go to this link listed below & download the printer driver software listed. When you save to disk you can choose where you want to save. Pick the folder you created. Save inside this folder. The HP driver (Will most likely be updated software). I promise, you will have a icon down by your clock when finished.
http://h10025.www1.hp.com/ewfrf/wc/product?product=59868&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7&lang=en&cc=us
Follow the instruction in your manual for setup & installation.
If you using Outlook Express & you want to print or send through your printer the page should be set as 8.5x11". Orientation should be set to Portrait, unless you set this for A4.
Lastly, please turn off your anti-virus software during install & re-install. Just in case you come back to this thread!
please vote...
Jan 30, 2008 | Computers & Internet
Canon PIXMA  iP1800 InkJet Photo Printer Logo
16 people viewed this question
Clive
Clive
old marine
old marine
Ekse
