Question about Kitchen Ranges
Maytag oven problem
I have a freestanding electric maytag range which the oven/broiler is not turning on. You can set the temp on the display but it doesn't trigger the oven to heat up? I have a similar problem; the oven has "clean" light flashing.We let it self clean for 4 hours and later unplugged it from the outlet briely.
It was heating the elements during "CLEAN" Cycle; but would not turn on
for baking or broiling. Please help? Any suggestions?
Thanks.
[email protected]
  • 3,037 Answers
Somehow, usually when cleaning the face of the clock area, you locked the oven control. Go into your manual, and it will tell you how to unlock it. If I remember right, try holding in the broil button for 5 seconds, that might take it out of the lock mode.
Posted on Apr 04, 2008
  • Benjamin Patri
    Benjamin Patri Apr 04, 2008
    let me know if that doesn't work, thank you and good luck
SOURCE:
Top oven replaced ignitor and still broiler works but oven doesnt .
since your broiler works, your valve should be good. Since you replaced your ignitor, the only other thing I would recommend would be the electronic oven control board. There is a sensor that is on the ignitor, the control board reads the signal (temp) coming from the sensor. If the control doesn't read that signal properly, it will not energize the gas valve.
Nov 22, 2015 | Maytag 30" Gas Double Oven Freestanding...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
Jul 04, 2012 | Maytag MERH865RAB Electric Range
Broiler doesn't come on
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 09, 2010 | Maytag 30" Self-Cleaning Freestanding...
Oven & broiler not heating on our Maytag MER5530. Lights on the control panel indicate it should be working. When I set oven temp, the oven "thinks" it's at that temp already. Turn broiler on and no...
May be the heating coil is bust?
The control panel is in parallel usually so as long as the controls are getting power they will turn on. But if the coil is gone you wont get heat. If you want to try fixing it, you may need a multimeter, or a continuity tester.
Jul 08, 2009 | Maytag MER5530 Electric Kitchen Range
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
